Question about Vizio VW32L 32 in. LCD HDTV
I have a brand new vizio 32L 40a flat screen I plug it in an I have the vizio name lights up but tv has no power an wont turn on an ideas?
  • 148 Answers
Assuming the Vizio name is the powerlight, then this is your problem and solution........................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not), please rate, thank you
Posted on Feb 03, 2010
My vizio tv just has the vizio light on when i plug it in it wont turn on
Sounds like a problem in the power supply. Possible bad capacitors if you can have it checked out.
Apr 22, 2013 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
47" vizio died
Very high failure rate on this brand. Even after repair, something else will fail. Cut your losses and buy a brand name set.
Mar 25, 2010 | Vizio SV470XVT 47 in. LCD TV
My vizio tv wont turn on. Any secret buttons that
Hi my name is Roety,
I can help you with your issue ,
 Check the AC plug, to reset the TV unplug and connect it. If the power light lights up check the input select button the TV needs to be own the correct input to view TV again.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 26, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
Brand new Vizio VW46LF acting strange.
If possible, I would suggest returning it and get another new one.
May 11, 2009 | Vizio L32 32 in. LCD HDTV
Vizio TV will not turn on.
I had the same problem. The orange/green light in the front was off as well. I unplugged it, held don the power button for one minute then plugged it back in. It's working now, but who knows how long it will last. I found that solution elsewhere on the site. Thanks for the tip whoever you are!
Apr 05, 2009 | Vizio VW32L 32 in. LCD HDTV
My son was hooking up the cable line to the TV and while he was doing that, he pushed on the screen which created a "cracked" look with part of the screen being white. Is there any way to fix this in a...
You need to take in the TV for repair. It needs to have the screen replaced. It might not be worth fixing since the screen nearly costs the same as a new TV. If it was damaged by accident warranty might not cover the replacement of the screen.
Mar 27, 2009 | Vizio VW32L 32 in. LCD HDTV
Child accidentally let the Wii slip out and hit the screen of the Vizio Vol 32L. Screen is cracked and we only get lines- horizontal and vertical. Is it fixable?
Sorry to give you bad news, the screen isn't fixable.
The cost of replacing the screen cost just as much as a new TV.
The Wii controllers seem to be the number one killer for HDTVs. So far, your the 20th person that fell victim to this.
Mar 17, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio VW32L 32 in. LCD HDTV Logo
607 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
