Question about Air Tools & Compressors
My 5.5hp honda is surging even with the belt off.is this carb. only or are thier orther factors,such as bad gas
    President:
  • 1,033 Answers
Bad gas can cause the engine to surge, but also the carb bowl and jets need cleaning. I usually drain the gas, remove the bowl, wipe inside the bowl , and then use a carb cleaner to spray the float and jet/s. The float may be hanging up. It would be best just remove the gas and clean the bowl area and float/jets. I wouldn't think replacing the carb. is the problem.
Posted on Feb 03, 2010
Why does my honda gc160 engine surge continuously?
Make sure that gas line , gas filter and air filters are clean .
Sep 06, 2014 | Honda GCV160 Engine
2012 honda rancher 420 without warning 2 hrs into trail, quad starts to chug and surge. then it quites. Start easy, but then chugs and surges again. If left for 2 hrs, no problem untill 2 hours into...
could be alot of things but start your daig.by determining if anything has changed fuel related... example.... could some water or bad gas recently been added to your gas tank or has poor fuel made it into your carb.float bowl?? Could some trash from fuel clogged a jet in the carb.? Also,some spark type problems are heat related. i.e. pulse coil generator pick-up
Aug 25, 2013 | ATVs
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
Honda pressure washer 5hp will only run with the choke on. Was running fine for about 1 hour
The problems you describe are usually indicative of a blockage in the fuel system somewhere in the carburator or a damaged gasket that's letting in too much air. With the choke on, the vacuum in the carb goes way up and forces more gas through. Remove the carb and check the gaskets and insulator if it has one. Then check the float bowl for debris and blow out all the passages in the carb.
Sep 16, 2012 | Garden
I have a honda 5hp pressure washer.I cleaned the carb and now when starts the gas fills the block!
The float needle is not closing all the way and fuel keeps leaking in to the carburetor. Replace the needle and make sure the float is not damaged and that the float pin is clean.
Mar 22, 2011 | Psi 2500 Mobile Pressure Washer 5hp Honda...
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Aug 17, 2009 | Honda 6370C - Parallel Power Kit For ...
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Mar 30, 2009 | Heavy Machinery
Air Tools & Compressors Logo
75 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
