Question about Olevia LT32HVM 32 in. LCD Television
Olevia 32" lcd tv made a loud, popping noise, shut off & now it won't come back on. When it popped, I noticed a spark
  • Olevia Master
  • 12,061 Answers
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Posted on Feb 03, 2010
Testimonial: "FixYa reply was the same I received from Syntax Corp. in California when I finally got to speak to a live person. FixYa is absolutely correct."
I can only see one channel on my Olevia 32, lcd tv. I have cable tv.
Posted on Jun 02, 2010
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
Last night our TV made a loud popping noise then the picture went out. We still have sound but have trouble turning the TV off. What could this be and is it fixable? Thanks, Anne Marie Orcutt
Question shows it is Vizio L32 lcd tv and symptom shows back light inverter board for defective for some reason and loud noise would be popping of any chip on inverter board.
Shopjimmy..com has replacement boards of that model on reasonable price and local tv repairman will replace defective board after checking/ testing the tv.
Hope these info will help.
Thanks.
May 11, 2011 | Vizio L32 32 in. LCD HDTV
My Toshiba Regza 32 inch lcd tv has a serious problem, on occasion the screnn will turn a fuzzy green color and turn itself off, usually a few loud popping noises also occur after it shuts off then the...
Model number means EVERYTHING to a real technician...
As a guess the popping noise could be arcing to ground - maybe from the inverter or one of the transformers on the inverter. The fuzzy green could be decoding the t-con board is attempting as this ground fault happens and shuts the unit off... I' would clearly have this checked before it does some serious damage. An ounce of prevention could save you pounds of cure....
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Toshiba REGZA 46RV530U LCD TV
My W3201C 32" LCD TV made a loud popping noise when I turned it off. Now it will not turn on. No power. No LED light.
That would be your transformer popping and dieing. Usually the popping is followed by a burning smell which is a good indicator that the part is unrecoverable. The cost of the part is variable based on the make and model TV and is usually not too labor intensive to replace. If not under warranty, let the repair gut know that you know what the problem is. Then, ask them to quote the cost of the replacement part and part number. Then ask them to quote you their hourly rate and get a time estimate. Then, google the part number and see if the cost is reasonable.
May 02, 2009 | Televison & Video
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
557 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
