Question about Haier HNSE05SS Stainless Steel
Our fridge keeps turning off! In order to get it on we have to turn the tempurature down to 0 then back up to the highest notch. Any suggestions?
  • 1 more comment
  • christie bar Jan 12, 2009
    I have the exact same fridge and am experiencing the same problem. What should I do? There's no ice chunk over the thermostat. The fridge isn't ever on long enough to freeze anything.
  • dadvw Apr 11, 2009
    I have a HNSE05SS haier refridgerater it runs for about an hour and gets nice and cold. Once the compressor shuts down it won"t start up again unless I turn the control in the fridge or wiggle it . What is that part and I take it it"s bad
  • daveatdacs Nov 04, 2009
    Have any of you figured out the solution to this problem? It is NOT what EmgSupport proposed. It's simply a problem with having to reset it constantly. If any of you have had this thing fixed let me know what it was please. Thanks.
    Problem Solver:
  • 10 Answers
Is there a ice chunk underneath the little freezer at the top?
Posted on Mar 08, 2008
  • Prince Charles England
    Prince Charles England Mar 08, 2008
    If there is carefully defrost and remove the ice. The sensing bulb for the thermostat is clipped directly under the freezer plate. If there is ice there, it thinks the box is cold enough and keeps the compressor off.
I have a mini fridge from chef mate that does not have a freezer in it. It won't keep temp cold even though it's on highest cold setting. Any answers?
in a fridge the highest or coldest setting is 1 or 0
the bigger the number the warmer the setting
door seal /door not closing properly
have a technician check out the thermostat for correct operation
Dec 10, 2016 | Refrigerators
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Freezer not freezing do i turn down to 0 or 1 or up to 4
The highest is the highest number so try 4 and see if it works
May 09, 2012 | Freezers
I cannot thread the machine. Specifically, I cannot get thread through the part that almost pops up when theflywheel is turned. How can I get thread through that? I also need a refreshed on threading the...
make sure the flywheel has been turned to where the needle is in it's highest position. Take the thread through #1 (machine should be labeled) and that should be a metal "notch" that holds the thread underneath to guide you down to #2 and if I'm not mistaken the thread guide for #3 is where you are having trouble. If your needle is in its highest position, then the metal guide inside the machine slot will also be at its highest position. Just take the thread back up, pull it back towards the back of the machine straight up and down in a 90 degree angle. When you pull the thread back, it should go through the slot opening. Once you have pulled it all the way back it should catch on to the metal mechanism in that slot. Then you pull the thread back down and continue on with steps 4 and 5 (threading), just look for the numbers on the machine...
Aug 04, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Jan 07, 2009 | Refrigerators
GE refrigerator motor wheezing
check behind panle where the fan is may be ice defrost the problem area
Dec 01, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Haier HNSE05SS Stainless Steel Logo
1,721 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
