Question about Refrigerators
The fan inside my galasy compact thermoelectric refrigerator is making noise why?
  • 1,531 Answers
Could be acouple of things ice build up around the fan
loose mounting braket and or screws or simply a fan going bad and needs to be replaced
Posted on Feb 03, 2010
Inside fan is working but heat exchanger ices up and fan freezes and unit won't cool.
This means the heating eliments are not coming on. Usually in this case I change out the heating timer, eliments, and thermostat. All as a set.
Aug 29, 2015 | Haier HRT02WNC 1.7 cu ft Compact Counter...
The fan makes a lot of noise, is there a way to replace it?
The type of refrigerator you have uses a solid-state device which likely uses a Peltier effect element. This uses electricity to transfer heat and cold on opposite sides of the element, absorbing heat from within and radiating it from the other side being cooled by the fan.
With no moving parts other than the fan, they are very reliable but also very dependent on ridding the element of the absorbed heat which necessitates fairly high air flow to function properly. If a fan was used that produced less noise, the airflow might be too little to allow the element to cool the interior efficiently.
Unless the fan has a defective bearing, which would reveal itself by a rattling sound, it is probably still working as it should.
Nov 28, 2010 | Avanti Compact Thermoelectric Refrigerator
My avanti thermoelectric compact refrigerator periodically runs very loud which is not normal. If I hit it, it stops and runs quietly again. Any ideas? I have already cleaned the dust off thoroughly and...
The noise if from a sympathetic vibration of the unit which transforms to vibrate any loose joints, parts or fittings.
You will need to listen to the noise, use your hand to hold up the plastics or the joints in the bottom section of the unit or the frame work. It will require a lot of patience to find the source of noise. Pad it up after tapping for loose noise on the rear and insulate the noise heard till you finally get rid of any vibration noise..
Aug 30, 2010 | Avanti Compact Thermoelectric Refrigerator
Haier Model HRT02WNC compact refrigerator not cooling what type of gas does it use?
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
May 16, 2010 | Refrigerators
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Should my haier 1.7 compact refrigerator run
this is a thermoelectric model and runs on a peltier junction. It will always have the fan running. That is the only moving part.
Jun 16, 2009 | Haier Refrigerators
The 5640 Coleman cooler motor runs, but unit does not cool.
This is a thermoelectric (TE) cooler. There is no gas' to replace in it's cooling system. It is possible the thermoelectric coupler has gone bad. Unfortunately Coleman does not seem to offer a replacement part. If you Google thermoelectric couplers, maybe you can find something on the web. Good Luck.
May 25, 2009 | Coleman (100076) Compact Refrigerator
Not getting very cold
thermoelectric needs a good heat dissipation. Give the unit a good ventilation to dissipate the heat, you will cool the unit. The cooler the ambient, the cooler the box. Remember not to reverse the switch, you will get a heated box instead.
May 24, 2009 | Avanti Compact Thermoelectric Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
