Question about Sharp R-1480 Microwave Oven
I replaced the pushbutten panel next to door now won't heat
  • 1,531 Answers
Need to make sure all you wires are connected properly,
and there is the possability the magnetron has gone bad.
Posted on Feb 03, 2010
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
Microwave oven won't heat
Depending on the model, it may just be a bad door switch.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
Here's the help file on door switches:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Or it may be a bad relay or connection on the the controller.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 29, 2013 | Emerson Microwave Ovens
Door won't engage and stay closed
Possible that the lock was broken and so the door opened. You can remove the front panel and check for broken plastic or nylon pieces which can be glued using instant adhesive.
Reset the lock and switch and the door must lock in correctly
Jan 21, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
I pulled the door off my advantium today to clean it after I cleaned the vent grille. I set the door carefully on it's side so I thought but a small little plastic piece broke off where the door...
Glue won't work, the part must be replaced.
We have the service manual at our site and you can download it free here.
You can order parts from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Advantium 120 Convection/Microwave Oven
The microwave door seems to be loose. The door will remain shut, but the light is on in the microwave and it won't run until I push upwards on the door. How can I tighten the door hinge?
you need a door interlock switch bracket adjustment; or, possibly one of the microswitches replaced on that bracket. it is behind that control panel.
May 16, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My microwave oven heats up sporadically. One time it does, then next time it doesn't.
its possible you might be a door switch problem...when you try to heat the food,an it dont work ,lift up on the door handle ,see if it starts working...you might need to replace the door switch or switches...
Nov 05, 2009 | Danby DMW773 Microwave Oven
Sharp R-1480 Microwave Oven Logo
21 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
