Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
My television powers up comes on for a second and then dies and the stanby light just flashes. i can hear the fans power up then it just dies straight away. How can i fix this? and what is the problem
  • Sony Master
  • 12,061 Answers
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Feb 03, 2010
Testimonial: "thanks man...how much am i looking at"
Powers on then right back of light flashes 8 times
Looks like a problem on the convergence board which requires repairing/replacing..
Oct 30, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
I have a philips tv model number is 60PL9200D/37. when i turn on my tv the blue power light flashes and the lights and fans cut on but not the actual screen. after a few seconds of blinking the lights and...
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Feb 03, 2011 | Philips 60PL9200D Projection Televisions
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 15, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
425 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
