Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Buzzing in a full freezer with icemaker model no. 253.44133802
I have a Kenmore Pro full freezer with ice maker. Model number 253.44133802...made by frigidaire. It's making a buzzing noise inside the unit at the rear of the freezer where the vent is located. The ice maker has also stopped working. Everything seems to work fine. Unit is cold, but the buzzing noise is constant and has been buzzing for 4 days. It doesn't sound like two pieces of light metal are hitting against each other. It does however sound like a high pitch rattle/ buzz. I've removed the power plug for 2 hours and replugged it. Its still the same. Any suggestions/ comments are greatly appreciated.
Megan R.
  • Megan Rovinski
    Megan Rovinski Feb 18, 2010
    Its 1year old and I'm also having frost buildups at the rear of the unit. How do you manually defrost the whole unit? You mean unplugging it for a day or two? I've never done that, didn't even know I have to do that..LOL.
  • 4,793 Answers
Try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Posted on Feb 11, 2010
Testimonial: "thx for the recommendation"
  • geoff hunter Feb 18, 2010
    although frost free, most units collect dust in vents,moss like substance in drains/pipes.and benefit from a total defrost and clean about once a year.vacuum pack food to be frozen,and keep door shut asap.
Model 106.58969700. Why doesn't ice maker make ice?
Could be many things, the water valve could be faulty, the icemaker thermostat may have blown, the gears could be stripped.
Jan 05, 2016 | Kenmore Elite Side By Side Refrigerator -...
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Icemaker stopped working suddenly. Water supply is working fine.Ice freezes but will not dump into bin.
Good day,
If the ice maker is the style with a wire to turn it off and on, and is in the down position, then the ice maker is bad, as long as the temperature in the freezer is 12 degrees or colder.
(The ice maker locks out at about 14 degrees or warmer.).
You can replace the module, and thermostat in the the ice maker, but could be as well the mold heater.
The price of repair is so close to a complete ice maker, that it doesn't pay to repair.
You might want to get the complete model number. Check with any decent size appliance parts house, they should have what you want, if going to Sears is an issue.
Feb 04, 2010 | Kenmore Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Kenmore Coldspot side by side. The ice maker will
Hello. You will need to replace the icemaker. The swicth in the head is causing the arm to stay up and is not repairable. If you can get me the model number I can get you the part number.
Jul 15, 2009 | Freezers
Ice maker not making ice
either the thermostat is bad or the heater isnt working. You could take the icemaker out and connect leads to the heater to see if it warms up or use an ohm meter to test the heater and thermostat. Also take the cover off and see if the cog wheel on the motor is broken.
Apr 29, 2009 | Kenmore Freezers
Kenmore icemaker won't work
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 26, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Items in freezer melting, Ice maker empty, fridge feeling warm
hi there,
you have 2 problems:
frist check the freezer thermostat and make sure that it's set to at least 5 or 6. if that is okay and you still have this problem, you may need to have the thermostat replaced and maybe more.
as far as the icemaker, if it's just the ice part that does not work, i would recommend checking the valve and water line coming into the icemaker.
can you tell me if this is a side by side or a top or bottom mount freezer? if you have the model #, that would be great.
Oct 10, 2008 | Kenmore Freezers
Freezers Logo
494 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
