Question about HP LaserJet 4101mfp All-In-One Printer
Network card (jetdirect 615N) no leds on, printer not recognized by either computer
  • HP Master
  • 32,281 Answers
When you connect the printer to the mains and switch on the printer and there no LEDs or menu panel are on, then there is a problem with the power supply in the printer.
The printer needs to be repaired.
Posted on Feb 03, 2010
Network can't ping jetdirect 615n card
why not ask at HP and not here, why ask on non HP forum.?
the HP enterpise forum covers this.
ask here first., they will direct you to OLD hardware help.
https://h30434.www3.hp.com/
here im searching there, see all those posts there.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=JetDirect+615N
Jun 08, 2017 | HP JetDirect 615N J6057A Print Server (In...
I have a plotter HP Designjet T610, which I have been making mistakes as I indicated in the instructions, but the error persists, it's 79:04 and I've tried the steps mentioned, such as turning off the...
The 79.04 error is usually caused by an IO port such as parallel or ethernet. If you have an ethernet port in this printer it is likely in the form of an HP JetDirect card. Turn printer off, remove this card and restart and your error will likely be gone. If the card has a model # 615N, throw it as far away from your printer as you can and buy a new card.
Mar 18, 2011 | Office Equipment & Supplies
HP 4100 has the 82.0180 EIO 2 Error and will not print.
Replace the Jetdirect Card. You probably have a 615N version and HP recalled them years ago with a free upgrade to the 620N. Google the Jetdirect 620N to locate a refurb. it should run you about $150
Jun 07, 2010 | HP LaserJet 4100n Printer
I have a HP 2200 Printer with a hp jetdirect 615n model j6057a Iam unable to get the printer to tell me the mac address. Help to locate MAC another way.
If you know the IP of the printer & the printer is connected to the network, try pinging the IP address of the printer.
After that, open a command prompt & type the following command then press Enter:
arp -a
This will display the arp cache on your computer. Check the list & find your printer's IP, & opposite to it, you will find its MAC address listed.
Jul 14, 2009 | HP Jetdirect 615n Print Server
HP 5500DN wont recognise jet direct card has been ok for 12 months?
Did you try another jet direct card??
It is a commen problem for the 615N card. Use a 620N and mostly the problem is gone.
Jul 10, 2009 | HP Color LaserJet 5500 Printer
How to replace jetdirect 615n with a new 620n
no you do not. the printer will have all the "knowledge" it needs. The same jet admin software will be used.
Mar 18, 2009 | HP 4100N 10/100 NIC LASERJET Printer p/n...
All printers with HP hJetDirect 615n card not printing
Known failure with the jetdirect 615s, the more reliable cards are the 610 or the 620. According to HP tech support stay away from the 615.
Oct 27, 2008 | HP Jetdirect 615n Print Server
All printers with HP JetDirect 615n will not print
Is the 615n an internal print server not one in the EIO slot. From memory if so it has a really high failure rate. Try getting JetDirect cards for EIO slots and seeing if they work.
HP 2420 Issue
Print a configuration page found under the info menu on the printer. Make sure that under options it shows the network card as being an installed otion (it will show enven if its a built-in embedded card) If it doesn't show you have a bad jetdirect card. If it does show make sure the IP address, Subnetmask and Default Gateway listed on the page match that shown on your SERVER & WORKSTATIONS.
If the card info on the config page reads 0000 then you will need to reconfigure the card through the menu.
If you are using a 615N Jetdirect card in the printer and it doesn't list on the config page it's most likely a bad card as they have been dying regularly. If and only if it's a HP 615N card, jump on HP's support chat at HP.com and go through the on-line chat. If your persistent and insist, they will replace the card for free. You will have to be persistent though and tell them to look up the service note that authorizes after warranty replacement. They know it's their but unless your persistent they will play dumb try and charge you. Hope that helps you.
Jul 11, 2008 | HP LaserJet 2420 Printer
Hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
Jul 07, 2008 | HP LaserJet 4200 Printer
HP LaserJet 4101mfp All-In-One Printer Logo
233 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
