Computer will not run windows xp anymore?
When I start the laptop it doesnt want to start windowsin stead it asks me to press esc to change boot order or press f2 to enter setup,f12 to change set up order. then it says operating system not found.
  • PGHPONY Jun 14, 2008
    Won't boot, black screen, says can't find operating system and I don't want to loose all the data on this Toshiba laptop by having to reinstall Windows XP... HELP PLEASE!
  • 123 Answers
Hello, do you have a floppy disk or anything in the drive? also check the boot order in the BIOS (F2) and see can your laptop see the hard drive. What is your Laptop, What is your version of Windows/Linux?
Posted on Feb 19, 2008
  • sillowayk Aug 03, 2011
    How does a laptop see the hard drive? What am I looking for in the F2 Menu?
Is there a way to get the 32 bit or 64 bit windows XP to install on a dell inspiron 6000 ?
as far as i can find out because windows xp does not exists anymore plus xp does not update anymore according to microsoft.
some new laptops will not allow windows xp to be put on..
if your laptop was xp to start with then it should work.
To specify the boot sequence.
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. ...
  2. Choose to enter BIOS setup. ...
  3. Use the arrow keys to select the BOOT tab. ...
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list..
  5. try and boot your disc this way if it still wont have it then your laptop may not allow it.
Nov 20, 2016 | Dell Computers & Internet
How to get to boot chooer on tne m700 starts
Hi.
  1. Turn on the computer. When the Compaq logo displays, press F10. Or,
  2. During Power On Self Test (POST), and after the memory check completes, press F10 as soon as you see a small white square flashing on the top right corner of the screen.
  3. In the computer setup, use the right arrow to move the selection to the Advanced menu.
  4. Use the down arrow to move the selection down to Boot options, and press Enter. The Boot options menu pops up with four boot order options.
  5. Use the down arrow to move the selection.
  6. Press the left arrow to change the order of Notebook.
  7. Press F10 to accept the change.
  8. Press ESC to jump back File menu, and then move the selection down to "Save changes and exit".
  9. Press Enter. If asked to save changes and exit, press F10.
On some laptops you can change the boot order by tapping the F12 key as the computer starts up.
Regards.
Jul 16, 2011 | Compaq Armada M700 Notebook
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
Can't install new OS
you need to install directly from the vista disc when the computer is powered on, put the disk in and it should ask you to press any button to start from cd..
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first. the computer should say what button to press to enter bios or cmos or setup when its turned on
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
ones you get into the vista setup you can empty the hard drive, getting rid of windows xp and then install windows vista over it.
Let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Toshiba Portege R100 Notebook
Cannot enter bios boot order
just when turn on notebook press esc then appear option f1 and thats all
May 10, 2009 | Toshiba Satellite U205-S5002 Notebook
Hello sir i have a new laptop insp-1545.in this laptop i have vista home but i want to format it an do re partion.who can i do that. plz told me
FIRST PLEASE INSERT THE OPERATING SYSTEM DISK.THEN RESTART THE COMPUTER.PRESS ANY KEY WHEN IT SAYS TO TELL YOU.THEN FOLLOW THE INSTRUCTIONS.WHEN PARTITION BOX COMES .PRESS "D" TO DELETE ALL PARTITION&"C"TO CREATE PARTITION.AFTER THAT INSTALL THE OPERATING SYSTEM
May 07, 2009 | Microsoft Windows XP Professional
Secondary drive 0 not found
Hi there.
Sounds like the boot order has been changed in the bios.
The secondary drive sounds like the CD drive as most laptops only come with 1 HDD installed.
Change the boot order to the primary drive by Pressing F1 during startup when the ThinkPad logo is displayed..
Once in the bios change the boot order, save and exit, the computer will restart and boot from the hard drive, when you get into windows check to make sure that the CD rom recognizes CD/DVD's.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | IBM ThinkPad T20 2647 Notebook
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
209 people viewed this question
Alun Cox
David Payne
David Payne
