Question about Bogen Communication Bogen Manfrotto 3030G Pan/Tilt Head with Quick Release Plate (green) Tripod
3030G pan tilt head
How do you manage the quick release plate?
There is a very small brass arm which is either one of two positions. Where is the arm supposed to be to really "lock" the quick release plate in tightly?
Is there any way to download a user's manual for this head - I just got a used one, no product info with it however.
Thanks!
  • 24 Answers
The little brass arm is supposed to be a safety switch. In one position the release lever bumps into the brass are and will not turn so the quick release willnot come off. In the other position the brass arm is away from the lever so it swings freely and the quick release plate will come off. With the brass arm open the quick release lever shoulde lock open until you push the quick releae in place. If none of this seem to work on your head, you may be missing parts. Try www.bogentripodparts.com
Posted on Jan 30, 2009
How can I fix the jerky motion of the 804RC2? What kind of lubricant can I use on the head?
Parts and a diagram can be found here: http://www.manfrottotripodparts.com/head804rc2-3.html
Silicon grease in very small quantities is the best lube to use. DO NOT use oil or liquid lubes like WD-40. These will flow and make the head messy and may "wash" the other lubes away.
Jun 09, 2011 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
I cannot figure out how to get the plate off the head. I end up either putting camera on, then twisting the whole thing onto the tripod, or putting the head on the tripod and twisting the camera around to...
Sounds as if you haven't unlocked the quick disconnect plate from the 222 head.
Release the quick disconnect plate from the 222 pistol grip with the thumb release it will click open and pop the release plate up a bit to remove it. The affix this plate to the camera tripod socket 1/4 x20 female thread on the camera bottom. The underside of the quick release plate has a "D" ring to screw it to the camera, fold over the "D" ring and when you pit it back on the 222 set the edge under the lip and set it down the brass pin then will snap the thumb release over and lock into place.
See my diagrams
And the release plate
Jan 22, 2011 | Manfrotto 222 GripAction Ball Joystick...
My Bausch & Lomb Professional Tripod 3 way Oil Fluid Pan Head Tilt Tension Knob is broken and the quick release plate is missing. Do you have parts for this unit?
Take off Ring Sitting Nob .... issue with tentionner Ring holder crack or base crake.. need to be change... Cause exessive force on the handle
Sep 29, 2010 | Bausch and Lomb Bausch&Lomb Master Tripod
I have a Samsonite tripod with a quick release plate. Is it possible to get another head? one that has a screw so that cameras can be threaded onto it?
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen. Because your tripod is not supported by the manufacturer; parts lists and pars are not available, you should measure the opening and see what other brand quick releases will work paying attention to the shape and locking mechanism. Otherwise just get another tripod.
Sep 02, 2010 | Samsonite 54" PhotoVideo Tripod w3Way Pan ...
The Pan Tilt Head cannot be removed from my Manfrotto CXPRO3
Extend the center column, there are 3 screws underneath that when unscrewed will allow the head to be tightened or loosened. The head is screwed on about 4 or 5 revolutions. You will need a flat head screwdriver. Take the center column out if you need to to be able to get to the screws.
Aug 24, 2010 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
The plate is stuck on the head of my 804rc2, maybe in backwards?
Yes, it would be really hard to put on and equally hard to get off. Make sure the safety lock is release and a flat blade screwdriver should pop off the plate once the primary lock is released.
Jun 30, 2010 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Quick release plate will not unlatach on monfrotto 488rc4
There should be a small brass lever that is a safety lock. You cannot unlock the main lever without unlocking the small brass safety.
Dec 19, 2009 | Photography
Bogen Communication Bogen Manfrotto 3030G Pan/Tilt Head with Quick Release Plate (green) Tripod Logo
410 people viewed this question
Top Bogen Communication Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
