Question about Maytag SDG3606A Gas Dryer
The ignitor does not glow red. The ignitor has been replaced once with no glow, so gas does not turn on and ther is no heat
  • 39 Answers
You might have a thermal fuse that has blown or a problem with the burner sensor or one of the burner coils is bad. If your not real familiar with taking apart your dryer you should call for service.
Posted on Feb 03, 2010
Gas dryer checked ignitor, thermal fuse and flame all had continuity still ignitor will not glow or heat
Will try to help you checked the igniter you say good if good does it glow if so clamp on one wire and take an amp draw while heating I like to see a minimum of 3 amps if glowing and 3 and above change the coils on the gas valve very cheap, now if not glowing and good ignitor the fun begins power comes out of the heat relay on the control board passes thru the thermal fuse then thermal cut off then hi limit then the flame sensor while also feeding the gas coils the neutral is supplied thru the centrifugal switch on the tumbler motor if the dryer stays running the centrifugal switch is good and you have a neutral bad flame sensor very rare since I am not there check the thermal cut off once blown it does not reset has to be replaced if all the fused I mentioned check good then check the heat relay on the board black and red wire stick meter ends in both off should read 120 volt when machine turned on should hear it click and meter should read 0 volts the boards seldom go bad but I have replaced a few in 5 years I am leaning more towards an open thermal cutoff
Feb 20, 2015 | Whirlpool Dryers
Heat won't go on...don't know if it's an ignitor problem, or a coil problem
UNPLUG DRYER REMOVE TWO PHILLIPS SCREWS UNDER FILTER ON TOP LID ....
FLIP TOP TOWARDS WALL REMVOVE 5/16 SCREWS IN TOP CORNER OF CABINET AN LEAVE DOOR AND FRONT CONNECTED REMOVE DRUM BT RELIEV IDLER BELT TENSIONER INFRONT OF MOTOR AND SLIDE BELT AND DRUM OUT OF CABINET AND SET OUT OF WAY TURN DRYER IN TIMED DRYER NEAR 60 AND LAY ON FLOOR INFRONT OF DRYER ON FLOOR INFRONT OF DRYER INFRONT OF BURNER TUBE AND WATCH AND LISTEN IGNITOR SHOULD GLOW RED THEN A CLICK THEN IGNITOR SHOULD LIGHT GAS ..... IGNITOR DOSENT GLOW CHECK WHITE PLASTIC FUSE ... IF IGNITOR GLOWS AND NO CLICK THE REPLACE FLAME SWITCH ALUMINUM AND BLACK BOX ON LEFT SIDE OF BURNER TUBE ...IF CLICKS AND NO GAS REPLACE GAS COILS
Jan 26, 2011 | Estate TEDX640JQ Electric Dryer
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Our stove was not heating up, but the electric pilot was glowing red, we replaced the gas valve, and it still will not heat up....what do you suggest?
Hi, The problem may not be so obvious. It sounds very crazy but the problem can still be with the ignitor even though it is glowing and heating up. The gas valve will not turn on unless the ignitor pulls a aet number of amps. of power. When theignotor ages it can stop drawing the same amount of power and the gas valve won't turn on because it thinks that the ignitor is not owrking correctly. I went through this with a couple of different ovens, the first one really took me awhile to figure out. Change the ignitor and your oven will work again!
Nov 16, 2009 | Ovens
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Thermostat seems ok, but gas won't flow from oven burner.
Hi, Even tho the ignitor is glowing, it is getting weak and will need replaced. The ignitor is not pulling enough amps to open the gas valve.
This is very common problem with the gas ovens.
If I can assist you further, please let me know.
Vic
May 29, 2009 | Garland H283 Gas Kitchen Range
No heat in gas dryer
Remove the front panel. Leave the door switch wires connected.
Turn the dryer on and look for the glow bar ignitor to glow red.
This may take a couple minutes.
No glow. Replace the ignitor.
Mar 05, 2009 | Whirlpool Dryers
Oven won't heat up
hi atdowhower,for your oven to heat the[ignitor]must heat up enough to open the oven safty valve.this happens by the ignitor drawing enough amprage thru the safty valve.just because it glows it may not be strong enough.or if you see no glow it may have a broke coil in that ignitor and wont glow at all.you wll need an volt meter to check if no glow.if soft glow,replace ignitor.shoul be very brite.God bless,tom
Jan 02, 2009 | GE JGRS14 Gas Single Oven
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
Maytag SDG3606A Gas Dryer Logo
76 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
