Question about Marshall 15 Watt Guitar Amp
While playing, the volume cuts up and down in all the channels.
GCM900 head
  • Marshall Master
  • 5,603 Answers
Fiirst check if your input connector is bad. Move the cable right at the connector and see if the volume jumps... HOWEVER before doing that even, verify your guitar is not the problemm using another amp.
If it is definetly the Marshal, it will likely need servicing.
It could be a bad volume control or a cracked circuit board.
Posted on Feb 03, 2010
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Right channel cuts out when I increase the volume
Blown or defective Headphone Amp IC or alternatively a defective Pot. Either way only AVID can fix it for you.
Outside parts and service is impossible.
Oct 03, 2012 | Digidesign *mbox2...
I have a RH50 T amplifier, it had a bit of a bumpy car ride to band practise the other day and now when i play through it, it will make a permanent buzzing noise on the clean channel that gets 70% worse on...
You may have damaged the variable resistors (the volume controls), you can purchase replacements from a local Electronics store (if UK based try Tandy). Otherwise have you checked the speaker itself for damage? You may have split the speaker which will need to be replaced.
May 04, 2011 | Randall RH50T Tube Series 50-Watt Guitar...
I have a Kustom KPM 4100 amp head that's cutting out. It works OK for 5-10 mins then crak snap crakle then nothing. After a cooling off period I can repeat the process. I have pulled the power amp and...
Have you tried connecting a single speaker to each output and cutting the volume down to see if you have a load or impedance problem? The amp may be perfectly fine except it's trying to play to a 2 ohm or less load :-)
Carl
Mar 16, 2011 | Kustom KPM4100 PA Amplifier/Mixer
With volume set at 0-3 no matter what channel it is on it sometimes plays quiet and sometimes plays normal and out of nowhere the volume spikes very high. Also there is not much adjustment above 3. The...
Plug a set of headphones into the EFFECTS SEND jack... only one side will have sound... now see if the level varies at that point... Note that the soumd will not be too loud and only in one ear... but we are wanting to find out if it varies at this point.
Jan 16, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
My 410 deville's channel switching doent work and is stuck on the clean channel. This really isn't a problem as I always use the clean channel and I only mention this in the event it helps diagnose the...
You may have a switch that may be bad. For the sound level high and low may need new tubes or possibly may not be seated fully into position. These tubes due get quite hot and do get loose over a period of time.Hope this helps.
Nov 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
On clean channel when 'channel volume' is adjusted, the sound cuts out, goes completely dead. I have to switch to another channel and back again or switch off and back on. The amp seems to get confused!
When it is working, wiggle the channel volume control WITHOUT rotating. If the sound cuts out, likely the soldering of the pot leads is broken where it attaches to the board. Try resoldering the connections.
SOMETIMES the control is damaged in which case it must be replaced.
Aug 30, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Marshall 15 Watt Guitar Amp Logo
173 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
