Question about RCA L32WD22 32 in. LCD HDTV
My L32WD22 doesn't seem to be getting any power.
My RCA model L32WD22 LCD TV doesn't seem to be getting any power. The supply to the back of the unit has been tested and found to be good. Worked fine about an hour before I noticed the problem. No lights or sounds come on by either pressing power button directly on the unit or by using the remote.
    Sergeant:
    Champion:
  • 277 Answers
Tnbanderson,
Pls take your tv to a tv service center and ask them to fix it. They won't be able to. So you make sure the make a workorder. When you get that order, you call 1-877-297-8391 and they will give you a tv
Posted on Jul 21, 2010
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
Our tv when itis on for a while some times the picture freezes an then goes blank an a loud hissing an squeech sound we have to unplug it to turn it off.
Hissing sound normally from Power Supply unit(PSU), usually from Transfomers in the PSU. Usually caused by bad capacitors. Try this capacitor replacement kit, on ebay only $15. http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Could not find any PSU board available at the moment, but have tried that kit and it works.
Nov 30, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
MY 32 INCH RCA LCD HDTV KEEPS TURNING ITSELF ON. DOESN'T TURN ITSELF OFF. ONLY ON.
Carol
These units bave a bad power supply. To get it fixed is easy.
Take it to a Servicer center where they repair tvs.
Since there are no srevice manuals they will not be able to repair this unit. With the Work Order in hand call 1-877-297-8391 and they will send you a tv.
Ps.. Make sure you get a work order or a copy.
Jun 22, 2010 | RCA L32WD22 32 in. LCD HDTV
My parents have an RCA model L32WD22 it made a loud pop quit playing but the power light still comes on
jdc432002
That POP was the power supply. Take the unit to a service center and ask to have it fix, Don't tell em I said it is a power supply, Just ask to have it fix. They will call to say that it is not repairable. So you take the work order and then you call 1-877-297-8391 and they will give you another LCD tv
PS make sure you get or have the copy of the work order
Jun 10, 2010 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32" HDTV LCD TV turns on, blue light on front is on but there is no sound and no picture. I left it unplugged for an hour and turned it on again. As soon as I plugged it in, an orange light on...
kkl,
these tvs have a power supply defects. Follow these instructions and get yourself a free tv.
Take your unit to a service center. Since they have no service manual they wii not be able to repair it.
With the Work Order or a copy of it call 1-877-297-8391 and you will get a tv no questions asks
Jun 05, 2010 | RCA L32WD22 32 in. LCD HDTV
Tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
I have an rca tv and vertical lines show up when i power the tv on model # is L32WD22
Tumble9827
Pls take your Tv to a Service Centre nrear you. Ask them to repair, and if they say they can't... Get that in writting on a Work Order,
Then call 1-877-297-8391
Dec 24, 2009 | RCA L32WD22 32 in. LCD HDTV
My rca l32wd22 will not power up what do i do
First place to look is the main power supply module for simple thing like fuse, then look for 5V standby, you must have at least this standby voltage. This 5V (should always be there with the TV on or off) is supplied to the main board so when you turn on the TV, the main board will send the ON signal to the main power supply to supply voltages to other circuits.
Nov 03, 2009 | RCA L32WD22 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32 in. LCD HDTV Logo
263 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
