Question about Dell 1710n Laser Printer
Printer stopped recognizing envelope and prints out address on the envelope as if it were sheet paper.
SOURCE: Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Posted on Jan 29, 2008
  • 105 Answers
SOURCE: Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Posted on Mar 27, 2008
  • 24 Answers
SOURCE: envelope stuck inside of printer
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
~~Cheryl
Posted on Dec 26, 2008
  • 24 Answers
SOURCE: Dell s2500 printer - multipurpose feeder not taking paper - never been used
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
Posted on Apr 07, 2009
jonb3838
  • 237 Answers
SOURCE: Dell 1700 only printing to envelope feeder
make sure that the manual feed tray is not set as default make sure you main tray is
Posted on Apr 30, 2009
Won't print envelopes
Envelopes may have to be fed individually through the single sheet feeder
Your word processing software may not have the correct parameters set for printing..
Jan 09, 2014 | HP Officejet Pro 8600 Premium
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I am unable to print an address on an envelope.... it comes out blank
It sounds like to paper setting is wrong. In the configuration you can set if the envelope in on the right side, left side or center of the paper feed. If it is set one way and you feed the envelope the other way the printer will print but on the wrong end of the feed area so nothing will be on the envelope. Try this, print an address label as you would on the envelope but just use a full sheet of paper. If it prints where you can see it, then feed the envelope on that side, or change the feed settings in your software to print on the other side. Office and most other programs have this setting. In MS word the orientation setting is on the envelope and label screen on the right side of the pop up box.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | HP LaserJet 1020 Printer
Envelopes won't print
where do i insert envelope to print address?
Apr 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Print Envelopes on HP Photosmart 7280
This is a paper size problem with the software, go to page setup and under "Paper Size" choose "User Defined" or "Custom" and fill in all of the dimensional information about the envelope and save with a name you will recognize. Now, when you print make sure you have selected the envelope from the paper list and you should be good to go. If you need further assistance, click "Ask Me" and I will answer your request as soon as I can.
Oct 07, 2008 | HP Photosmart C7280 Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Oct 15, 2007 | Samsung ML1740 Laser Printer
Dell 1710n Laser Printer Logo
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
