Question about Lexmark T630 Laser Printer
Lemark T630 says close front door or insert cartridge
  • Official Brand Answer
  • 3,344 Answers
I have seen that same problem before, here is a great step by step guide on what to check and how to resolve it.
http://bit.ly/bRJweI
Hope it helps.
Posted on Feb 13, 2010
It says "close door or
There is a switch inside the front door (cartridge door) on the left side, you can see it in a little hole in the black plastic. Inside you can see the metal part of the switch. If you press it you can ear the "click" of the switch. This switch must be pressed to clear the message " close door". Probably it's only out of regolation, you can by-pass it if you insert a small piece of paper inside the hole to close the switch.
Apr 27, 2011 | Lexmark T630 Laser Printer
How do I change the toner cartridge
Open the front door. press the green button and pull the cartridge insert the new cartridge and close the front door
Jan 15, 2011 | Sharp AR-M350U Copier
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
Error 32 Unsupport Print Cartridge Lexmark T630
on the inside of the top cover on the left side when the door is open there is a little switch youll see a little metal tab 5/16'wide push on this and see if the error clears. if it does this can be adjusted. if not pull the cartride out there are two sensors on the right inside one close to the front this is an optical sensor blow this out with canned air if you dont have an air compressor. then further back inside there is a two pin sensor make sure that if you push in on these that they dont stick. next there is a smart chip on toner caartridge that lines up with those pins when its installed clean these contacts. doing all of these things usually geets rid of the problem. no parts have been replaced recently right? check the connector to the logic board this is theeonly 3 pin connector that has black and white wires. this sohlud fix your problem
Nov 24, 2009 | Lexmark T630 Laser Printer
Lemark Z1300 - need help installing
Begin by making sure power is on and ink cartridges are installed. DO NOT connect the USB cable.
Insert your CD and install the software. Connect the USB cable when prompted by the software.
Note: If you get any "New Hardware Found" windows pop up, just close them out.
If you do not have a CD, use the Comment button to reply and I will lead you to the Lexmark site to download the software.
Thanks for using Fixya.
Sep 18, 2009 | Lexmark Z1300 InkJet Photo Printer
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
T640 printer put toner in the error message states please insert
Please remove the cartridge and then re-install it to make sure it is seated properly. Then close the front cover door and make sure it latches completely. Now turn the printer back on.
Mar 31, 2009 | Lexmark T640n Laser Printer
Close door or insert cartridge
check in your backside of printet any paper jam
pull that paper thats it.
also pull the cartridge and refix again it
Sep 30, 2008 | Lexmark T642 Laser Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Lexmark T630 Laser Printer Logo
464 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
