Question about GoVideo Go Video DVD/VCR Combo
My Sony DVP-C600D disc player's disc tray will not stay closed. It will close all the way and then make an improper noise and reopen. How do I fix this?
2 Suggested Answers
  • 157 Answers
SOURCE: Go Video Dual Deck VR2940
Hello bettysgarage. A common malfunction in DVD players. The mechanics has a bad part or something is jamed in the rails, arms, lifts, ect. I suggest you unpluge the AC, remove the case screws(note witch screw went were), and look internaly for something in the mechanics, thread, paper, loose paper clip, ect. Carefully postion unit and reconnect the AC so you may see the action of the disk tray in motion. Please be careful you have AC power and can get SHOCKED if you touch the circuit or wire terminals. When no object is found you have a bad DVD that would require a local service technican to repair unless you are technically inclined to vinture futher. Good Luck.
Posted on Oct 08, 2008
Tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
I have a dvp-c600d dvd player 5 disc tray. a pin broke inside on the dvd tray located on the bottom tray of dvd tray I put a new pin and dont know where to align the wheels for tray and disc position and...
Did you find a solution? I have one to and the disk tray is misaligned and I don't know how to fix it...and I have no info showing on the digital screen..other buttons don't work..so I don't know if I have to reset the machine...could you tell me how to rest it?
Aug 06, 2010 | Sony DVP-C650D Multi-disc DVD Player
The dvd tray will not stay closed
this is a serious problem the disc tray is most probly broken u either replace or ask a xpert aroung ur locality .....................i could not help you out b'cause i cant c the problem with my own eye..........
I HOPE UR XBOX GETS FIXED............
Mar 02, 2009 | Microsoft Xbox 360 Console
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Jan 21, 2009 | Televison & Video
Sony DVP-CX995V
Its problem of incomplete unloading of CD tray so system control in player sense it and generate command to close it.
CD Loading mechanism needs service and cleaning to loading belt.
If you have electronics experience, you can make it easily. let me know if you need further info.
Nov 20, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
GoVideo Go Video DVD/VCR Combo Logo
56 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
