My receiver will not play in dts mode at all. (RX-V 2400)
    Brigadier General:
  • 8,546 Answers
Page 4 of the manual discusses the Input Mode button and how it prioritizes multiple audio signals from the same device. Could that be the case? Try Auto.
Page 35: "If the digital output data of the player has been processed in any way, you may not be able to perform DTS decoding..."
Page 83: The connected component is not set to output ... DTS digital signals."
Posted on Feb 03, 2010
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
I have a Yamaha RX-V663. I recently upgraded to 7.1, but the 6th and 7th speakers do not activate on DTS HD Master Audio Blu rays. The 6th and 7th speakers do activate on DTS True HD, DTS EX - ES,...
It is unclear to me as to what you mean when you say they do not activate. Does that mean that they just don't play, or does it mean that your receiver doesn't show them on the display? If your not hearing the sound from the speakers, are you sure your dvd movie is capable of outputting 7.1 or is it only 5.1?
If the receiver doesn't show the speakers on the display, try running through the speaker setup again to make sure you selected both sides and rears for the setup.
Good Luck
Jan 06, 2011 | Yamaha RX-V663 Receiver
In the display it shows(decoder off) and not able to play music ,how to turn on the decoder?
I sense two different problems or one not completely described.
The followinbg would address the decoder issue.
It partially depends on what it is you're trying to play or how you like to hear it.
Check the Direct Mode Button and make sure it's not activated. (M on page 4).
Straight Mode (L on page 4) is a desirable starting point for multichannel material.
See page 24 of the manual to see all the things this beastie can do with all of the audio inputs.
http://www.retrevo.com/support/Yamaha-RX-V465-Receivers-manual/id/23270ag803/t/2/
Be advised that most commercial multichannel sound sources have been pre-mixed by the originators to provide an intended 'feel' and 'space', so modifying it might not be an improvement although it can provide a novel change. Like any spice, a little is best.
I find that processing 2-channel audio through the various DSP modes can make for some interesting and arguably pleasing effects.
If you 'search' the document for the word "decoder" it may lead you to a setting that's out of place.
"Not able to play music" should only happen if you have a source incorrectly chosen or the source is DTS and the decoder is off. Undecoded DTS will sound like high-level digital 'hash' noise because you're hearing the raw 'data' so it must be decoded to turn it into audio.
See the note on Page 2 regarding DTS-CD's then look at Page 33
I hope this was helpful.
Jan 03, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
DTS option shows on the display when playing a DTS movie, but unit will only play in Dolby when trying to select listen mode...I can't select DTS mode
That is a typical function of the movie you are watching..changing the sound mode can "usually" only be done by selecting it on the disc, or by using the audio button on your player depending on the model.
Dec 23, 2009 | Kenwood VR-407 Receiver
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Mar 01, 2009 | Yamaha RX-V663 Receiver
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
65 people viewed this question
 Grubhead
Grubhead
