Question about Sony Playstation 3 (PS3) Console
When my PS3 is turned on the red light stays solid no matter what. Physical buttons do not function at all. 4 different controllers (verified charged) have been unable to get a response... it just stays red with no reaction. Have tried multiple power cords and swapped out the hard drive for a different ps3 formatted drive. It's hard to know where to start when it will do so little...Any ideas?
  • willd89 May 11, 2010
    hi what model of the ps3 have you got i.e. 40gb 60gb or 80gb? thanks
  • Sony Master
  • 12,061 Answers
Your Motherboard is faulty. Needs repair or replacement.
Posted on Feb 03, 2010
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
May 20, 2011 | Innovage Jumbo Remote Control
My PS3 has had the YLOD 3 times now and I've repaired every time myself. Each time I repaired it last about 6months before it gets hit by the YLOD again. After repairing the console for a 3rd time I was...
Thank You..... Thank You... Thank you.. for answering your own question :) I was going through the exact same thing and couldn't figure it out for the life of me. Only difference was this was only my second re-flow. I know I did everything perfect too. Because like you mine last 6-8 month's. Not two weeks some some who don't put the added tlc needed. After reading your solution I noticed that because of the way that ribbon bends. Some of the beads were protruding from the ribbon. So I pushed them down with a plastic fork prong so I wouldn't rip it. Then flipped the ribbon so it wouldn't bend over the end again. Thank you again Chilled....
Sep 01, 2010 | Sony Playstation 3 (PS3) Console
Need help with the codes for a innovage jumbo universal remote . instruction for T.V. brand name symphonic
Well First, make sure the device you want to connect with your remote is turned on, whether thats the television. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the TV. Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn’t recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed TV.
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program TV. The LED light should blink once and then remain a solid red.
Good Luck!!
Thanks
Jan 16, 2010 | Televison & Video
Completed ps3 update to 3.00, controllers stopped responding
If you still have the PS 3 manuals, try pairing the controllers to your console again by following how to synch it or push the reset button from the back of the controller.
Sep 10, 2009 | Sony Wireless Controller for PS3
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Codes for jumbo remote
TV codes 0013, 0018, 0028, 0031, 0034, 0043, 0046, 0052, 0058, 0072, 0081, 0084, 0134, 0135, 0141, 0150, 0162, 0182, 0187, 0199, 0208, 1019, 1033, 1036, 1071, 1077, 1149, 1150
vcr codes 4015, 4032, 4012, 4020, 4052, 4017, 4039
Turn on device that you want to set
Aim remote at the device
Press the device button for the item you wish to program and the LED will blink once
Press and hold the set button unti the LED lights up solid red
Using the number keys, enter the 4 digit code from the list. After you have entered the 4th digit, the LED will turn off, indicating that the code for the device was recognized.
If the device powers off, test the functions for the other buttons (except OK button). If all the functions work, press the OK button to store the code. If the indicator light remains solid red after blinking 3 times the code is incompatable. You then need to restart back on step 2.
Make a note of the correct 4 digit code for future use.
COde search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Aim the remote control at the device
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Aug 18, 2008 | Televison & Video
Remote code
Looking for other codes, but while im doing that you can try
COde search function is an alternative method to programming your device without using the code list
Aug 09, 2008 | Televison & Video
Innovage jumbo universal remote
Code Retrieval
Jan 23, 2008 | Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
427 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
