Question about Yamaha Dtxpress Iv Special Electronic Drum Set
I've got this Machine Yamaha DTxpress Special yesterday, connected to my motu 8pre as (stereo channel), connected my midi in it, it works good with Nuendo, sonar etc espcially with EzDrummer and Addictive. The problem i am facing is that when i hit HI-HAT on drums it triggers TOM on addictive drums. What should i do, heard about some mapping, but how?
    President:
  • 1,138 Answers
Have a look at the update at their site and see if it helps:http://www.xlnaudio.com/?page=downloads
Posted on Feb 03, 2010
Reset motu 8pre
Press the volume control in for 5 secs., when a "D" appears onscreen let go and rotatefully clockwise till "OK" appears.
Bingo
Feb 18, 2014 | Motu 8pre 16x12 FireWire Audio Interface
I have a light snake midi to usb cabel an its suppossed light up when you plug it in but when i plug it in the computer dosnt recgonize the connection at all and the cord does not light up indicating that...
You MAY need to connect a MIDI device to it to get it to light, not just plugging into the computer. The MIDI communication current comes FROM the device being driven an ONLY flows when a device is CONNECTED.
Jan 04, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
In some pictures for the Yamaha DTXpress IV Special, the hit-hat has this trigger system under it and other pictures don't.What is it?
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Midi Output
If you only have a stereo output from the DT you need to record audio to a sequencer track so you can remix it better.
Dec 10, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Does it have the option to load other sounds in it?
Here is the manual if you don't have it:http://www2.yamaha.co.jp/manual/pdf/emi/english/ssdrums/dtxp4_en_om_d0.pdf The set comes with 427 drum/percussion voices and 22 keyboard voices. If you use a midi cable plugged into the midi out on the sound module you can control other midi sound modules and midi devices by plugging into the midi in on them. Page 30 of the manual describes some of the parameters. If this helps please let me know.
Nov 19, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
Aug 26, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Problems with DTXpress III special bass drum pad
If you are comfortable with working on it and the warrantee is up try taking the pad apart to see if the piezo element has come loose from its mounting or if the solder joint is loose. If that isn't the problem save your settings and initialize the set according to the instructions in your manual.
Aug 09, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
282 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
