Question about Roper Refrigerators
Black pieces appear in ice bin after ice is made
  • 4,066 Answers
If it's fairly old the ice mold may be flaking off the non stick surface. You may can order a new ice mold if you get your model number.
Posted on Feb 03, 2010
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: ice maker won't flip ice into bin
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jun 09, 2010
woodchuck789
  • 4066 Answers
SOURCE: The plastic "rake like" white
The part that came off is the one that pushes the cubes out. Each end is round and fits into two holes in the ice mold. Since yours came out it may have broken on one end or the the hole it fits in could have cracked. If it's not broken you should be able to slightly bend it to put it back. Here is a diagram showing where it goes. Part 11. http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0804041-00012.png
Posted on Oct 18, 2010
My lg side by side refrigator ice maker it will make ice but doesn't always come out of the tray
About once a week, I have to take the ice bin out and empty the ice in a large bowl, remove the stuck-together pieces then return the ice to the bin and replace the bin. Good luck.
Feb 12, 2017 | LG Refrigerators
HOW TO REMOVE ICE MAKER STORAGE BIN ASSEMBLY IN FREEZER
empty freezer put a pot of boiling water under the ice bin and let it melt it
May 10, 2016 | Refrigerators
Howtofixicemaker
First, is the auger drive operating when you press the dispenser lever? Is the ice frozen into a clump in the bin and isn't breaking loose into smaller pieces capable of dispensing? Is there frost around the ice dispensing chute (just above your glass) or inside the ice bin (near the very front) indicating an air leak? Is the bin installed properly so the bin auger drive is connecting to the bin auger?
Knowing these answers will point you in the right direction to solve the problem.
Sep 13, 2014 | Amana Refrigerators
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
I only get crushed ice even when the button is on
Pull the ice bin out and you'll see a rectangular hole with a plastic piece that has a rectangular hole in it. This piece will correspond to a steel rod that runs along the bottom of the ice bin. This steel rod actuates the crush/cube option in the dispenser. Sometimes icing can cause the plastic piece to get stuck. Try "jiggling" the plastic piece up and down until it frees and operates easily. Then replace your ice bin and try operating the controls on the dispenser again.
Dec 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker chute becomes jammed with snow and cubes are being crushed even if the cube option is selected
You need to remove the ice bin , remove ( save ) the ice , and defrost the bin opening with hot water . It sounds like a piece of ice got caught behind the bin flap , keeping the flap from opening fully , so cubes will go thru . When cubes cannot go thru , the crusher will crush anything that tries . Now this is the ice container only .
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Button set on cube - only sends out crushed ice
No , the panel is probably ok .
1 ) remove the ice bin
2 ) in the back of the freezer , you'll see a square hole , with a white rectangle piece inside , which you should be able to lift upward , with your finger . If this piece doesn't lift , then it may be corroded with rust , or be bad . When you call for cubes , this piece lifts up and in the process , lifts the long rod , attached to the ice bin . When the rod lifts , it opens the bin flap , allowing cubes to be dispensed . If it does not lift , the cubes will be ground against the cutters , therefore , dispensing crushed ice .
3 ) to access this solenoid which lifts the cube actuator , remove the 3 or 4 screws on the sides of the PANEL , and with the panel removed , you will have access to the solenoid and actuator .
4 ) you can check the solenoid for continuity , voltage ( when arm pressed for cubes) , or possibly a loose wire .
Jul 28, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice doesn't come out into glass. Makes some ice but is larger pieces stuck together or flat pieces in bottom of container. Green light in back of container is on. I set the freezer to colder temp but...
You are not using enough ice.
You may need to dump the bin every week or so and keep fresh ice in the bin.
When you go through several defrost cycles the ice tends to eventually melt and stick together.
Mar 10, 2009 | Refrigerators
Crushed ice only
pull out your ice bin.  in the back of the bin you will see a rod protruding from one side.  That rod goes into an opening in the rear of the freezer. the plastic piece in that opening raises and lowers the arm on the ice bin giving you crushed or cubed ice.  check to see if that plastic piece is froze up or if your rod got stuck on top of it.
Oct 29, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
79 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
