Question about Okia 420w UL Approved ATX Computer Power supply (OKIA420ATX) Power Supply
I have a Okia 420ATX power supply. I had it
I have a Okia 420ATX power supply. I had it checked out today at Microcenter. They sadi all the voltages check out OK. But the fan only turn for 2 seconds upon turn-on, otherwise the computer and fan are dead.
Was the test at Microcenter faulty? other ideas?
  • ejrode Feb 03, 2010
    wjbtms,
    the power supply fan does not stay on - it just spins for a few seconds when power is first applied. No lights or sign of live is present in the computer.
    No I have only looked beyond the power supply - that's out of my league. I believe my next move is to buy a power supply from Microcenter, try it, and if that solves the problem then the initial testing was faulty.
    thanks - ed
  • Bill Brown May 11, 2010
    There is a fan on the power supply. Does that stay running? As you look into the computer, are there any other led (small green or red) lights on? If the microcenter stated the supply worked ok, is there another working computer you could try it in? If that works, then the first one is bad. Have you done any work on the computer other than removing the power supply?
    Novelist:
  • 157 Answers
Based on the additional information that the power supply fan turns on for a few seconds and then goes off indicates to me you have a motherboard or processor problem. I would have a service center check the computer for you.
Posted on Feb 03, 2010
I have a Power Supply OKIA 550W black, and i whant to know what kind of sensor thermisor I have to use for reparation. Because it burned and I cant read it.
If burned out, it is most likely a MOV surge supressor. Since most PC power supplies are 120/240 vac rated, a MOV of 275 volts or greater would work. The exact values are not critical, as it is for line surge supression.
Jun 13, 2010 | Okia (OKIA550WP4PS) Power Supply
I have an OKIA 350ATX power supply in my system that I need to replace, but I cannot find one. Could I use one of these 450W ones? http://www.bccpc.com/bccpc/power_all.htm
as long as your using atx and your system isn't one of those micro systems that needs a special smaller power supply then yes you can use that one
Oct 15, 2009 | Okia 350w UL Approved ATX Computer Power...
I have an OKIA power supply that was installed last September. The fan has stopped working allowing the tower to overheat. Is this model OKIA 350-ATX still in warranty?
Yes, the factory provides a 1 year warranty. Since you installed it some 11 months ago I suggest you contact them asap. You'll probably need to provide the serialnumber to them as part of the procedure.
Okia is not actually the full name, the company that makes them is called Broadway Com Corp and their (powersuplly) website is: http://www.bccpc.com/bccpc/power_all.htm
The contact information can be found at: http://www.bccpc.com/bccpc/contact.htm
Aug 12, 2009 | Okia (OKIA550WP4PS) Power Supply
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
No power to motherboard
Could be one of these:
1. Lead Fuse could of blone
2. Fan broken
3. Insted of the power, it could be your motherboard
4. THE WHOLE THING
Im sure your get it fixed soon and i hope me telling you what it could be has helped you.
DigicalJAI
May 19, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
I have a okia 500atx power supply. When I attempt to turn on the computer, it will stay up for about 3 seconds then turn off. is the power supply the problem?
CHECK THE FAN REMOVE ANY DUST AND SPIN THE FAN PLUG IT IN AND TURN IT ON IF SAME PROBLEM THAN THE FAN IS BAD IN THE POWER SUPPLY AND YOU NEED A NEW POWER SUPPLY TAKE IT WITH YOU WHEN YOU GO TO THE COMPTER STORE FOR A NEW ONE
CANDYMANGANDY
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
My sound on my ASUS OKIA-420ATX is not working
put mb cd and install sound driver.
go to control panel and click add\remove programs and there right click properties device manager and there if u get yellow questions marks in sound device select that and right click and install driver
Jun 10, 2008 | Computers & Internet
Fan
Hi replace the fan by opening the power supply with a new fan if your power supply is under warranty period still get it exchanged.
May 19, 2008 | Okia 250w UL Approved ATX Computer Power...
Power Supply Warrenty
I couldn?t find a web site for Okia either; however, I did note that the venders that sold them usually guaranteed them for one year themselves. I would at least try that route, that and not buy Okia power supplies. There are lots of stories and physical examinations of how poorly they are designed and manufactured.
Sep 19, 2006 | Okia / 450-Watt / ATX / 80mm Fan /...
Computers & Internet Logo
239 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
