Question about Logitech Harmony 880 LCD Remote Control
Intermittently Working Correctly with DirecTv
I have an 880 and it has worked problem free for about 2 years. I recently bought a new TV and reprogrammed the remote for the new TV. It worked fine for about a month or two.
Now, when I try to run the Watch TV activity, it doesn't always work. It turns my LG TV on, it puts it to the right input, it turns my DirecTv receiver/PVR on correctly, but then the remote basically freezes. None of the commands will work for either the TV or the PVR.
If I switch to a different activity (such as watching a DVD or powering off), it functions fine. When it does this, I have even tried using the 'official' PVR remote, and that doesn't work either. Sometimes, when I switch activities a couple of times and go back to Watch TV, everything works fine again.
Very frustrating!!!
Do you think it is the remote, or maybe just a problem with my pvr?
    Sergeant:
  • 300 Answers
Update your Harmony remote control software on your PC to the latest. Go into the TV device settings. The software should recognize if there is an update to your TV's IR commands. Try the same things with the DVR.
It's also possible the TV and/or DVR are locking up due to IR commands that are being sent too quickly. The remote has a setting for the delay between commands sent to the same device as well as the delay between commands sent to different devices. Try adjusting these settings:
  1. In the Harmony remote software on your PC, click the "Devices" tab.
  2. For the "TV" device, click the "Settings" button.
  3. Click the dot next to "Adjust the delays" and click Next.
  4. Adjust the "Inter-key" and "Inter-device" delays to something higher and click Next.
  5. Follow the steps to save the changes.
  6. Repeat steps 2-5 for your DVR device as well.
-=Zzed=-
Posted on Mar 04, 2008
SOURCE:
I have a 1 1/2 year old dolby digital flat screen tv. The remote stopped working so i bought a new remote. It will not work either. Is there something I can do?
See if your remote will work when standing in front of the tv. Since you bought a new remote and it is not working either you may have a bad power sensor or board on the tv set. Is the new remote the exact replacement for your tv set? If not it may not be programmed correctly.
Mar 04, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Philips DSR708 DirecTV DVR hangs up after power up
Is this a new issue that has shown up on the receiver? If so then you might have a bad hard drive in the receiver causing it to hang on boot up. Also these units require two inputs from the satellite antenna so that could be another possibility.
Nov 17, 2009 | Philips DSR708 DirecTV DTV Receiver /...
When I go to the guide grid om my Directv right arrow doesn't
Found instructions in another post for removing the back plate. Trying to clean contacts and buttons to make it work.
Sep 11, 2009 | Logitech Harmony 880 LCD Remote Control
Tom Tom One won't charge up
THE AVERAGE BATTERY LIFE FOR THESE IS 2 YEARS, YOU ARE WELL PAST THAT, U NEED A NEW BATTERY.
Aug 31, 2009 | Tomtom ONE GPS Receiver
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Directv AV1 switch Volume Problem
Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
Aug 03, 2008 | Universal Remote Control DIRECTV Universal...
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Emerson Jumbo Universal Remote and Directv
We're having the same problem here with the Emerson Jumbo remote and Directv, also having a problem with the Magnavox combo VCR/DVD
Jan 12, 2008 | Televison & Video
Logitech Harmony 880 LCD Remote Control Logo
339 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
