Question about Remote Start System
I have a Viper LE 5301 remote starter. Currently,
I have a Viper LE 5301 remote starter. Currently, none of the functions work--will not remotely start or unlock doors. When I press one of the functions, it will light up on the remote but the vehicle does not respond. What is the problem??
How do I do that?
Posted on Jan 08, 2013
  • 344 Answers
Rest the modual to factory default
Posted on Feb 15, 2010
  • LINDA WILSON Jan 08, 2013
    How do I do that?
Vehicle will respond but not lock/unlock
reprogram the remotes by following the vehicles owner Manuel
if you can't get them reprogrammed then its dealer time.
Mar 11, 2014 | 5301 LE 2 Way Car Remote Starter System
Crank but no start
If your truck already has a factory alarm you will need to get a pass module installed to bypass the factory alarm.
Jan 28, 2014 | 5301 LE 2 Way Car Remote Starter System
Remote starter not working
Check to make sure the remote start kill switch isn't broken. There should be a switch under your driver seat or gas pedal that turns your engine off if someone tries to drive off with your car while you're warming it up. If that switch is damaged, it can trick your remote start system into thinking there's someone in your car, and preventing the system from starting up at all.
Dec 12, 2013 | Viper 5301 4202V Remote Start System and...
Horn does not sound when locked by viper 5301
??? Have u tryed a new battary. ???? is there a way to re program it ck online or call the DLR..
Feb 05, 2012 | 5101 LE 1 Way Car Remote Starter System
Remote starting diagnostics says "Manual
A tach MUST be connected for manual transmission installation. Start there.
Jul 01, 2011 | 5301 Responder LE 2Way Remote Start and...
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
Remote Start System  Logo
637 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
