Question about Black & Decker Professional PI8000 Iron
When I turn the iron on the iron on the reset button light and light above it comes on, but no heat like the iron isn't on. How do I get it to come back on?
  • Black & Decker Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
When I plug in my iron the light comes on but when I go to push the button to turn it on it does nothing, not even heat up. The iron is only 3 months old
Good Day!
Please open the cover of your iron and look for the thermal fuse inside.That is the only problem of your iron replaced it on the same ampere and temperature.
Thank you and don't forget to rate my answer.
May 10, 2011 | Irons
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Black and Decker steam iron won't heat. It has a green stand-by light and a yellow on light. When plugged in and the dial turned all the way up, the stand-by light is the only light on. The yellow light...
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you in any way that we can.
While this doesn't actually solve your problem, I hope the information allows you to make an informed decision as to how to proceed from here. Please let me know if I can be of further assistance.
Aug 22, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black and Decker AS775 Iron won't reset to heat up.
heatman101
May 22, 2008 | Black & Decker AS775 Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Black & Decker Professional PI8000 Iron Logo
154 people viewed this question
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
