Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
    Scholar:
  • 198 Answers
Posted on Feb 20, 2008
Screen flashes vertical lines when turned on
try a different monitor it sounds just like you think a failing monitor
Jan 15, 2018 | Mag Innovision LT776s 17" LCD Monitor
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
My mag inovision monitor was very slow to warm up and come on line, now it won't com on at all
Power Supply, replace the caps, 220uf,470uf,680uf. You will see the tops of them are popped out, check the board too see if its turning color from the surface mount transistors that drive the lamps. If its turn on very dark color the parts in the monitors are very stressed out.
Then you may need to replace the monitor.
Rate me if this helps.
Mar 15, 2010 | Mag Innovision Computers & Internet
Mag 17
it is a problem signal cable of the monitor open the monitor test the continuty of 15 pin signal cable
if pin no 13 & 14 (hsync & vsync)are open then change the cable problem will be solved
Oct 25, 2008 | Computers & Internet
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen had multi-color vertical lines, then went black
the monitor has power board issues it is not your video card. its not dead but it will require some soldering work to repair.
May 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
I think it's busted
you need to open the case and check the capacitors and if they seem doomed or color is leaking then replace the bad ones that should stabilize the power to the vertical ic chip
Nov 20, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor took half an hour to warm up, now won't start.
doubtful this is a driver issue warm up is not needed for any monitor. this is a power board issue internal to the monitor capacitors or some issue on the main power board. let me kow what you will do. good luck.
Nov 18, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
327 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
