Question about Refrigerators
The bearings are worn out which makes for a lot of noise-is this a warranted part in the 1 year parts and labor .A service guy came out and looked at the refrigerator and said it was not a covered part.The part is being ordered and it will take 2-3 days from today to come in.
    President:
  • 1,515 Answers
Hi, you did not say what part has bad bearings. You have the evaporator fan motor in the freezer, the condenser fan motor in the lower back and the compressor which also has valves and bearings. The only part That is covered in the years warranty is the compressor. You can buy an extended warranty for that for up to 4 years. The other motors I don't believe are covered at all, maybe in the first 30 days. That's not right I know, but that's how it works. They normally last for years?? Best of Luck, you may want to call the place you bought it from and talk to them about this motor. It is worth a try.
Sincerely,
Shastalaker7
Posted on Feb 03, 2010
2007 holden epica 2.5l manual has noise only when clutch is depressed
The throw-out bearing is worn and making the noise. The bearing only have pressure on it when the clutch is depressed.
Advise to have new clutch plates installed along with new throw-out bearing since it's all apart anyway and just a few more dollars for the clutch plates. It's a lot of labor.
Good Luck
Sep 22, 2017 | Holden Cars & Trucks
Rear wheel bearings
Get a different shop to check all of the suspension components - if the struts both snapped, something is going on that's a much bigger concern than the wheel bearings. Look for bent control arms and other suspension components - check clearances and bushings everywhere in the rear, make sure nothing was installed backwards or forgotten. Struts don't just snap, and bearings should definitely not die every couple thousand miles. Also, have a dealer look at it, to make sure that things are installed properly. It won't be cheap there, but they might notice something that other shops routinely miss. I hate suggesting that ANYONE go to a dealership for service, but in this case, they're the most likely to notice something out of spec...
Oct 18, 2012 | 1995 Volkswagen Jetta
Our washer just started making loud popping noises while running. It still washes just fine
Some washing machines are made with hardened plastic parts instead of metal. You may have a plastic knuckle( used during the wash cycle to aggitate the items) that has worn a bit and needs replaced. I had the same issue with our Kenmore a few years back. The replacement knuckle was $100 plus tax. If you are handy with instructions and your hands it is something that can be done at home with the proper tools and time. I had no time to fix ours and the service charge cost $150.
Jun 03, 2012 | Maytag Neptune Washer
Its like a horrible noise like its stuck i dont know how to explain the noise its not a clicking noise. its like a screaming noise and it really only does it when the weather is cold
Check out your hub on that side. If the wheel bearings are going out, it will make a noise as you describe. The wheel bearings and hub are a 1-piece assembly that is relatively easy to change, and doesn't cost a lot in parts. Stand in front of your vehicle a ways, directly in front of the wheel. Does it appear to lean in at the top? This would confirm that your bearings are worn really badly, but isn't always obvious.
The other part that can make noise in those conditions are the CV joint on that side, but it's usually a clicking noise when you turn really sharp, especially when in reverse.
Oct 29, 2009 | 2007 Chevrolet Blazer
Broken heat exchanger
Yes. DO NOT USE IT UNTIL IT IS FIXED! Carbon monoxide can kill you! Most manufactures will warrant their heat exchangers on 80% furnaces for twenty years. Some models only ten years.
Tubular heat exchangers are known to be very durable. If this went bad this fast the most common cause would be a faulty installation. The installer should have adjusted the gas pressure to assure proper firing of the burners. The air flow should have been adjusted according to that models rated temperature rise. And the flue pipe needed to have the proper rise, length, diameter and height to properly discharge the moist flue gases.
Get a new heating guy. Even though you have a heat exchanger warranty that will cover only parts, not labor. Unless your installer sold you a ten year parts and labor warranty. A contractor will probably charge you a flat fee of $300 -$400. or an hourly rate with trip charge and 1 1/2 - 4 hours labor. A good tech should be in and out of your home in 1 1/2 - 2 hours.
Good luck
Mar 28, 2009 | Heating & Cooling
Breaking at slow speed there is a bad bearing o scrunching noise.
This is a hub issues. the bearings are dry and i would get this looked at before they get to dry. i would also check the entire axle assembly as well. just too be safe. i suspect the bearings will need to be replaced. (repacked)
Mar 15, 2009 | 1999 Chevrolet Malibu
Warranty in service date
MFG should be 1 year parts and labor.......Unless you bought the extended warranty
Oct 07, 2008 | Sony KDF-E42A10 42 in. LCD Television
I have Hitachi 50vs69a abd it is 1 and a half years old, it has created a blue spot in middle of screen and yellow tint from the sides
I had a certified Hitachi service guy look at my tv and he said it was the light engine. Called Hitachi customer service and they were aware of issues with this part. They agreed to cover the part if I would pay for the labor. Labor cost me around $250. Hope this helps.
Jun 01, 2008 | Televison & Video
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
