Question about Sharp LC-19SB25U 19 in. LCD HDTV
The power light is blinking and when you can turn the tv on it stays on for about 20 seconds and turns off on its own.
  • sunshine7669 Feb 03, 2010
    How would I know what a power supply board looks like? You are speaking a different language to me right now. I know cars and computers but not TVs.
  • 10,515 Answers
I Suspect Power Supply Board.Open the TV and look for Power Supply Board. Once you find the Board, Pull out the Connectors. Take the Board out. With the help of magnifying glass, you need to check Cold Solder Joints.If not, then Check the Caps and Fuses. I imagine, if this could be due to Power Shut Off, you would be able to Find Some Bulged / Swelled / Leaked Caps. You would smell Ammonia kind of odor. You need to pull them out. Order the same Caps online or go to Radio Shack. It would cost you few bucks, in fact less than 20 bucks. Once you get the Caps, solder them and it is all set.
Note - You need to take all the Precautions as this would involve Voltage.
Let me know, if problem persists so that we could further troubleshoot.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
  • taran_2005
    taran_2005 Feb 03, 2010
    Thanks for your response!!
    Look at the below link :-
    http://cgi.ebay.com/SHARP-LC-19SB25U-POW...
    This is How the Power Supply Looks like in your Model.
    Let
    Hope
    i helped you.
    Thanks
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
TV power lights blinks on after turn on.
you need to post make and model#
Dec 31, 2013 | Televison & Video
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
Blinking lights on HP MD6580n
Sounds like the power supply is overheating.
Oct 05, 2012 | HP Md6580n 65 in. HDTV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Television turns on and off
Almost certainly the lamp.
Apr 09, 2009 | Televison & Video
Power off automatically, the red light in front of the tv blanking, remote / button can not shut off tv, only unplug the power. After 20 seconds replug the power, tv turns normal, but it happen again and...
Good Day,lizbg;
Check the solder connections at the negative side of both C809 and C810. Resolder if necessary. This a common problem with model.
Good Luck, Big Irish.
Jun 14, 2008 | Toshiba 42H81 42" Rear Projection...
Tv turned off
When the tv shuts done does the power light blink? If so what number does it blink? That will tell me which circuit your problem is in. Notice the number of blinks then let me know. Also what is the model number of your set.
Jan 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
My 2 month old 37" LG HDTV won't turn on...
just resolder capacitor then use a pc fan on iy
good luck
Dec 06, 2007 | LG DU-37LZ30 37 in. LCD HDTV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Sharp LC-19SB25U 19 in. LCD HDTV Logo
67 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
