I have to manually turn on and off my cold water valve at the wall or it will run non stop. meaning if i forget for a little too long ill flood my house.
  • 4,059 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Feb 03, 2010
Testimonial: "thanks woodchuck789! your speedy help is very appreciated."
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
Lavamat problems
Most likely, your washer's fill valve is leaking. You can probably find replacement valves. I found the AEG LAV1480 parts at several sites.
If your water pipes to the washer have shut-off valves where the hoses connect, turn the water to off after doing the wash. If they don't have shut off valves, have them installed. It's a cheap way to avoid floods when either the valve or the hoses fail. There are some high-end electronic shut-off valves that include a timer so you won't forget to turn off the water. Two simple 1/4 turn shut-off valve (one for hot, one for cold) are cheaper but you have to turn off the water after you finish the load.
To test the shut-off valves when in the closed position, disconnect the hoses from the washer and put a bucket under them. No water should flow into the bucket beyond the water that was initially in the hoses.
I hope this helps.
Apr 29, 2012 | AEG Washing Machines
Stops mid cycle
Sounds like a cold water problem. Try running washer set for cold water only. See if it stays running. Most rinses are cold water. If you have low water pressure it can stop due to protection circuit that allows washer to fill for only so many minutes. If it isn't full at end of time span, it may shut down. Try checking inlet valve screens for restriction. Turn off water and remove hoses from back and look into place where you removed hoses. You should see a screen in each one. Scrape out build up with a small screwdriver. Flush out with water.
DO-NOT remove screens to clean. If any debris gets into valve it can cause valve to remain open, flooding house.
Apr 01, 2010 | Zanussi ZWF1640 Front Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
The water feed to the ice maker will not shut off.
Either the water valve has stuck open or the IM water switch is stuck. Unplug the wires from the water valve and see if the water has stopped. If yes it is the switch, if still running in the it is the valve.
Eric
Jun 20, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Very little hot and cold water comes out when machine is on.
Hi. you may have a water pressure issue within the plumbing. i would call a plumber out just to make sure of this possible issue. Until then, you can check the water valve inlet screens for debris or any blockages in that area. Make sure the wall faucets are fully opened on both the hot and cold side. one more thing, if the plumbing and water inlet valve screens are OK and, the wall faucets are fully open, there may be a internal issue with the water valve assembly not opening fully. In this case, i would recommend replacing the water valve assembly.
Please rate and god bless:)
Apr 02, 2009 | Kenmore Washing Machines
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
