Question about Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television
My tv mitsubushi ws 48913 wont come on at all
  • Kim Yearick
    Kim Yearick May 11, 2010
    Could you provide more information. Does the standby light blink? If so how many times before reset? Anything odd just before it quit? Any problems over the last several weeks which seemed odd but didn't cause it to quit? Any power surges in the neighborhood recently? Let me know and I will try to help. Hardrocko
  • 111 Answers
Does it have a green timmer light that keeps flashing?
Posted on Feb 03, 2010
I have a Mitsubushi Model WS-65511 Projection TV . Green light is flashing on the front, screen won't come on. tried resting , no change. What could be the problem?
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Apr 15, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Factory v chip codes
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the remote TV control at the same time, when your
password is requested. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
Jan 21, 2008 | Mitsubishi WS-55807 TV
I need a manual fot mitsubushi CT29GB1 as I was
Mitsubishi's TVs are much better their cars but some have a weird tuning system. Under the cover for AV3 input (lower right front of TV) is a small recessed button marked 'preset'. Push this, then choose 'Auto' to scan and load the channels then choose 'Manual' to adjust and reassign them to the right channels.
Jan 17, 2010 | Televison & Video
My tvs led light blinks for 50 seconds befor turning on
Like all mitsubushis have the possible leaky tube problem and it only has to leak one time one or two drops to make all kinds of crazy things happen so first someone needs to check inside the tv with it unpluged of course if one of the tubes have leaked on module and then dried it could be building up corrosion causeing problems
Sep 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Convergence Problem with Mitsubushi WS-65315
It is best to replace the convergence PWB, rather than trying to repair it. After its replacement, convergence adjustments should be done again. If you wish to get some details; visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
http://electronicshelponline.blogspot.com/ Convergence procedure to projection TVs are given in detail.
May 18, 2017 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Power wont stay on
Check for coolant leak on signal board = bad CRT.............T.
Feb 28, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi Medallion HDTV1080i
MY PAWNZ-MOST LIKELY A BAD DM MODULE.THE ESTIMATE ON THOSE SEEMS TO BE ANY WHERE FROM 300-600 BUCKS.MAKE SURE YOU GET A MITSUBUSHI EXPERIENCED TECH.JOE TV
Nov 13, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
