Question about Xerox WorkCentre XD100 All-In-One Laser Printer
What does j2 mean on a xerox work centre xd 100
Cwrc@earthlink.net
  • Anonymous Jul 20, 2008
    I replaced the drum cartridge, but the J2 continues to show and not accept the change. How do I resolve that? I also have a new toner cartridge for it, but that does not seem to be the problem.
  • lgsurgmd Aug 21, 2008
    I also have the xerox x125F and J2 error. I replaced both drum and toner cartridge but it won't work and J2 still appears. Any suggestions? thanks leila
  • 3 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Posted on May 28, 2009
  • Fixitmore Jan 28, 2011
    Xerox XD100
    To clear J2 fault after replacing drum.
    Drum counter reset procedure:
    1) Enter Diagnostic mode: C (clear), Auto, C (clear), Auto.
    2) Drum Count Reset:(24-7): Select '24', 'Print', followed by '7','Print', followed by 'Print' again. This resets the drum count to zero.
    Genius:
  • 1,601 Answers
Drum Cartridge end of life error. Time to change it.
Posted on Feb 19, 2008
  • 30 Answers
H4 is fuser problem, probably needs the fuser tube replaced. Remove cabinet back (just a couple of screws), and open right door. You'll see fuser unit secured inside right door with 2 screws. Follow the wires out of the fuser to the place in the back where the connector is located. Press little latch on connector, and pull connector to disconnect fuser. Remove 2 screws securing fuser, and withdraw fuser unit from machine. The glass tube in the center of the fuser roller needs to be replaced.. it's the heater element.
Posted on Mar 10, 2009
Sorry, does anybody have or know what H4 error means.
Posted on Sep 19, 2008
Xerox Work Centre XD120f - J2 error message. Lost manual need new one.
J2 means the drum unit has reached the end of its life. You need to replace it.
Staples . office max etc normally has them in stock.
If not google a company called The Parts Drop.
They will have what you need also.
Oct 24, 2010 | Xerox Office Equipment & Supplies
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
J2 error on xerox xd 100 copier
hello there:
here is a link that will be able to help you out
  1. XD100 Style: Trouble Shooting Xerox brand models: XD100/102/103/104/105, XD120/122/125/130/155, XL-2120/2130 ... Next month, we'll hit the J1 & J2 codes as well as the L codes...www.enxmag.com/OLD SITE/bhorvat2304.html - Cached
Sep 14, 2009 | Office Equipment & Supplies
XEROX WORKCENTRE XL2120
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
1,127 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
