Question about GE Americana A4425GDTWW Side by Side Refrigerator
Water will not despense through door? - GE Americana A4425GDTWW Side by Side Refrigerator
  • 4,059 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Posted on Feb 02, 2010
  • ssiever3 Oct 17, 2010
    Switch works for the ice maker but no the h20. There is no "Click" ( assume the selinoid) for the h20. probably the selinoid?
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
My GE GSS25VFPAWW side by side refrig. wil not despense water.
I turned off the unit for an hour with the door open and the ciller tubes thawed. the water started wotking again.
Dec 26, 2009 | GE GSS25VFPWW Side by Side Refrigerator
The flap on the ice despenser is not closing and water is forming in the pan below. Is there an scamatic of the door ice maker despenser?
If you can look up and see the flap is loose or sloppy, you need one of these two kits. Kit # 8201649 is the chute door, door bracket, spring, damper pot.
Kit # 8201756 contains all the above plus a metal bracket designed to replace the housing bracket, the door pivot pin and a metal brace.
May 10, 2009 | Whirlpool ED2FHEXM Side by Side...
My whirlpool side by side
If you can see the water running through the line when pressing the button in the door it must be going out somewhere inside or under the unit. If this is correct your plastic water line needs repaired.
let me know what you find.
Phil
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
General electric refridgerator won't despense water in the door
Have the same thing happen a few times. The posted solution is correct, but in the mean time you can thaw the line by heating with a blow dryer inside and outside the door, and around the ice dispenser. This should take about 15 mins.
Jun 03, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
No water thru door
I would try putting on the light at the dispenser. It worked for me but took almost 24 hours to work. I am now keeping the light on all the time. Simple solution to try. My ice was working when the water was not coming out.
Feb 06, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Water despensing all of a sudden very loud
needs to defrosted and the filter needs to be changed
Dec 24, 2007 | LG LSC26905TT Side by Side Refrigerator
GE Americana A4425GDTWW Side by Side Refrigerator Logo
444 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
