Question about CyberLink POWERDIRECTOR 7 VLICDELUXE for PC
Powerdirector 8 created dvds will not play
Powerdirector 8 ultra created dvds will not play on dvd player. i have to save the file, open and burn using windows dvd burner and then it will play on dvd player. i have windows 7
When i play my dvd's video it not work video can't display
Posted on Feb 03, 2010
My DVD Slideshow will only play on my PC.
To play on a dvd player the files must have an extension the dvd player understands i.e. .avi, .mpg4, .mvk etc.
May 17, 2016 | Computers & Internet
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
How to record
You will need a burnable cd /dvd rw disc and cd dvd rw drive and burning software there are lots of these freeware on the web here is just a few you might try if you dont have a burning program
if you dont have two cd / dvd drives to do a copy disc
you will need to create a folder to copy the music to then burn it to a disc
to make a folder right click in my documents select new folder you can name it lets say my music blues for the sake of this exercise
click start all programs accessories open windows explorer navigate to your music cd
select the cd right click copy and then paste the music into your newly made folder folder or
click and hold the cursor and drag and drop the cd into your new folder
if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your folder in my documents
once you have done this open up your burning software depending on which it is you can choose either a data cd or dvd or burn an image you would select the option make an audio cd or music cd depending on the burning sofware
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files
if you need more help with this post a reply
Hope this helps
Oct 22, 2012 | Emerson MP530 MP3 Player
DVDs burned with Pioneer DVR-110D do not play on the same burner
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
Jul 25, 2009 | Pioneer DVR-109 DVD±RW Dual Layer...
DVD-R
maybe your DVD writer is not a multi/dual format (dvd+ & dvd-), check your writer if the print in front is "DVD-RW"(minus format) or DVD+RW(plus format),
for burning home movies and create a DVD so that you can play it to regular dvd player, i suggest to use xilisoft DVD creator.here is the download link, if ask for password on extracting. pw:www.dl4all.com
DL: http://rapidshare.com/files/164261293/Xilisoft_DVD_Creator_3.0.39.1114.rar
Ultra Burning Pack 4 [AIO]
Includes:
AnyDVD & AnyDVD-HD 6.3.0.0
CloneCD 5.3.0.1
CloneDVD 2.9.1.2
CloneDVD Mobile 1.1.6.0
Virtual CloneDrive 5.2.0.2
GameJackal Pro 2.9.18.610
Enterprise EE Client 2.9.18.600
Enterprise Manager 2.9.18.600
Alcohol 120% 1.9.6.5429
Nero 8 Micro (En/Ru) 8.1.1.4b
UltraISO Premium 8.6.5.2160
Free a.k.a Lite 4.11
Pro Advanced 4.10.218.0
http://uploading.com/files/LRPOVSVH/Ultra%20Burning%20Pack%204%20(AIO)_www.dl4all.com.part1.rar.html
http://uploading.com/files/B3GJG4GZ/Ultra%20Burning%20Pack%204%20(AIO)_www.dl4all.com.part2.rar.html
Feb 26, 2009 | Roxio Easy CD & DVD Burning
Home dvd player won't play a burned dvd
Not all burned DVDs are compatible with all home DVD players.
Some things to do to help compatibility:
1. Use only DVD+Rs.
2. Burn at a slower speed (4x or below).
3. Make sure the software you are using to burn the DVD creates a menu. Most DVD players won't be able to play a DVD unless there is a menu; usually you can tell the software to skip the menu if you want but it still must be encoded onto the DVD.
Thanks and please take a moment to rate this solution with a fixya rating. :c)
Jan 25, 2009 | Ahead Software Nero 6 Ultra Edition...
CyberLink POWERDIRECTOR 7 VLICDELUXE for PC  Logo
600 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
