Question about Hobart Welders IronMan 210 MIG 500304A Welder
I have a hobart ironman 210 that lost all power but no circuit breakers blew switch is working but no power output to cooling fan or gun
    Champion:
  • 225 Answers
Take side panel off where power goes into unit,check for voltage ,if not go to where plug is plugged into check for power if there is power check the crows foot to make sure all three wires are tightly screwed to terminals
Posted on Mar 07, 2010
My Hobart Handler 120 stopped working during a welding process. Now when I pull the trigger, the 30a 110v circuit breaker trips. The machine can be turned on and the breaker holds (cooling fan in the...
Please don't give me a bad rating for this. Its just a little extra info. you didn't mention that may help you find the problem. Depending on your specific model, there should be 1 or 2 breakers on the unit it self. If there is only 1, it will shut down the entire machine when tripped. If there are 2, the top one is for the whole unit and the lower one is for the wire feeder motor only. There is also a thermal overload that will shut down everything except the cooling fan. Secure the trigger closed and let the fan run for a while to see if it re-starts when cooled. If the depth of the weld was stable before the problem occurred, I would suspect a short in the motor and not the rectifier. That is not a sure bet though. If the transformer does not start when it cools, UNPLUG the welder and short the transformer to ground to be sure the capacitor is discharged. Then isolate the feed motor and transformer and use an OHM meter to test them individually to ground for a short. With a little luck, it will be the feed motor. Please let me know if this helped at all. I am new and still learning how to explain what I am thinking. Thanks for writing us.
Roger
Apr 02, 2011 | Welding Tools
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Hobart 210 makes an arc but the wire feed motor won't turn. used very little ,has voltage at motor,worked fine the last time i used it
hi,
maybe you haven't got the wire speed control turned up probly not the answer but sometimes its the simply things.
Mar 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
My 210 took a spill. Looking for new face plate, cables, & knobs. Where can I find them?
Hobart are very obliging, contact them and request a parts list for your set, or any Hobart welding suppliers.
Nov 15, 2009 | Hobart Welders IronMan 210 MIG 500304A...
I am looking for Hobart parts I think???
you can go to any welding store(praxair,air gas)and they will be able to order the parts you request,need to get all the imfo.you can off of welder for them to be able to help you.
Jun 09, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Excessive wire speed on hobart ironman 250
to find out if you need a new reostat disconnect the wires from it and put an ohm meter on it and check the ohms resistance it should read up and down ohms as you turn the dial.
Mar 02, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Hobart Welders  IronMan 210 MIG 500304A Welder Logo
183 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
