Question about Maytag Neptune MDE5500AY Electric Dryer
The dryer heats up and spins just fine but doesn't dry clothes, smells like burning
We just built a house so the vents are clean. Need some help about would to do? Thanks
  • orthotist Feb 20, 2008
    The dryer vent is only 6 " long to reach the wall and is not bent, mashed or anything like that. Thanks!
    Any more suggestions?
    President:
  • 1,314 Answers
Look behind the drier with a flashlight and see if the connecter vent got mashed or folded over when the drier got pushed back also what kind of vent are you using back there if its long cut it short as you need if its folded over on its self that cuts its flow in half
Posted on Feb 19, 2008
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
My Kenmore 600 is not even 2 years old. It spins and appears to have heat but the clothes do not dry. I cleaned a ton of lint from the flex pipe/elbow joint in the rear of the dryer but this has not...
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
Dryer heating but not drying the clothes
be 100% sure there is a good air flow outside the house where the dryer vents out this is the most comon problem. Next check in side the dryer drum at the back give a slight tug on the drum toward the front of the dryer you are looking to mack sure there is not a gap between the bulkhead and drum felt. If there is a good seal there then I would repace the Theremostat on the blower housing this is the cycle theremostat
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
71 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
