Question about Tapwave Zodiac2 Handheld
Tapwave2 backlight out
The back light on the tapwave 2 is burned out. Do you know what I need to repair it and do you have the parts. I just replaced the battery. Dan
  • Dano122 Apr 02, 2008
    Thanks for the response: The backlight went out around 3 months before the battery finally died. Thought it might have been the lower output of the old battery couldnt power the backlight. So got the new battery but the back light still did not work. guess it needs a new screen. Cant seem to find one. If you hear of one let me know. Thank you. Dan
  • mrsmcg Jun 04, 2008
    Tapwave dropped... backlight no longer works. Checked cables, everything seems okay. Wondering if there is a fix for this problem, or if I am out of luck and need to start shopping for a new pda.
If the backlight went at the same time as you replaced the battery, check to make sure you didn't damage or loosen any cables in there.
Posted on Apr 02, 2008
I have an insignia tv ns-lcd42hd-09. If I have no backlights and cannot see the menu with a flashlight does it still mean the inverter is bad or is it the t-con or main board.
That brand TV will not display anything on the screen if the backlight is burned out. Depending on how much you paid for it, you might come out better just replacing it that repairing it. The backlight stretches the length of the screen and it only takes one diode to go out to cause the whole TV to go out. If you are a DIY person, know you will be dealing with 50-70 screws. NOT counting the plastic mounting screws for the front and back bezel.
The other kicker is the availability of the actual part. The LED strip used for the backlight WAS a proprietary part and is supposedly available only thru the manufacturer. However, it is possible to replace it with a modified strip from strip LED lighting, a little soldering, and a little bit of know-how. This will void the warranty, but, if it fixes your TV for actual pennies on the dollar, you cut out the middle man by doing the work yourself, you're looking at about $50 for parts.
Hope this helps. http://www.indoffofficefurniture.com/led-retrofit
Apr 25, 2017 | Insignia Televison & Video
LED tv backlight issue
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 17, 2016 | LG 42LN541C - 42" Class 41.9" viewab LED...
Hello, we we have a 50 inch Samsung Plasma TV, from Bestbuy, went to bed and it was working fine, woke up and now we have audio, but NOTHING on screen, completely, black...also tried DVD and same thing,...
Tries tv unplung,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.Tv now 50/50 the tv might work as normal again.If the tv dosen't.Tv have a dead 1 or 2 backlight buffers boards have to be replacing.These 2 long backlight buffers boards only job are to provided a tv plasma screen panel for a backlight to see the picture.Tv now the plasma screen panel have no backlight that why ur tv have only audio sound and no picture.No experience in tv repair and never done any electronic board parts replacement before.Best just call many tv shops and explain the tv situation it in and get the best quote prices for parts and labors.Best prices parts and labors should be around $400 is fair more than that as i said shops around for more tv repair shops.
Aug 19, 2011 | Samsung HP-R5052 50 in. Plasma HDTV
My screen for my zodiac tapwave 1 has a brown blob on it, like it was crushed. Is there an easy fix it for this?
Sounds like the LCD is broken. Tapwave has been out of business for a while now, so replacement parts aren't readily available; however, if you go on ebay and look for "Tapwave Zodiac Demo" you may find a demo unit. You can take the LCD off of this unit and replace your broken one.
Here is one listing
Hope this helps,
Bill
Sep 22, 2009 | Tapwave Computers & Internet
Dashboard lights burned
You can not. The unit is a solid state, with a circuit board on the back. non repairable bulbs.
You should take to dealer , there is an open recall on the dash assemlby. Chevrolet will replace the unit with there exchange program.
Aug 14, 2009 | 1995 Chevrolet Tahoe
The screen is black but if you look hard you can see the background very lightly
Hi, your monitor's backlight is burned out or malfunctioning. The LCD monitor consists of two major parts - the LCD panel where images are created, and the backlight which forces light to pass through the LCD panel so you can see things. Your backlight is out. Viewsonic has great warranty support and service. You should contact them, provide them with the serial number, and they'll probably repair it under warranty for you. This is a hardware malfunction, so it needs to be repaired.
May 15, 2009 | ViewSonic VA1912w 19" LCD Monitor
My 3 year old Dell Inspiron 710m screen won't light up
to see if its your backlight, shine a torch onto the screen and if all is visible then, your backlight is out.
they are not expensive but getting someone to replace it may be.
Dec 20, 2008 | Dell Inspiron 710m Notebook
Tapwave Zodiac2 Handheld Logo
49 people viewed this question
Top Tapwave Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Tapwave Computer and Internet Expert? Answer questions, earn points and help others
