Question about Sony Xplod XM-554ZR Car Audio Amplifier
On my amp theres no light to show that the amps on there is a power protecter light but thre is power getting to the amp
  • 24 Answers
Explain in better details what is happening if the amp wont power up jump a short wire from the positive on the amp to the remote if this powers it up check youre remote wire for bad connection
Posted on Feb 06, 2010
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
No sound from my ja 687 amp lights show receiver is working
Need to check on the power supply to the output drivers, if there is no response on the speakers it is possible that the output replay is under protection. You need to remove power plug and leave aside for an hour before the amplifier is plugged back. If all functions show on display but there is no sound check the PREAMP output- audio out. If there is audio then the fault is with a non switching of the power amp or a power amp protection. Since these are mounted boards with little access to testing you need to be skilled to go further to probe and proceed. Also Denon might refuse to service if the amp is tampered which also can be expensive.
Oct 25, 2011 | Denon AVR-687
I have a dual electronics 4 channel amp that goes into protect mode as soon as i throw power to it
unplug all the speaker from amp then power on. if you still have a protect light amp is bad and if you have no protect light continue to hook up each speaker one by one while amp is on till you get a protection light and that speaker would be the source of your problem
Jun 02, 2010 | Dual Car Audio & Video
I have no Running Lights in both the front (Amber), or the back Tail Lights (Red), no liscense plate lights, back-up lights or instrument panel lights. I do have Brake Lights, turn signals,...
1st check the fuses-----then the globes-----check all the fuses some have multiple tasks if you have a test light ,youcan test to see if thre is power on one or both sidesof the fuses with the lightswitch on.if thre is no power there the swich is the next place to checkfor power to those items not working. i cant remember if there is a relay on those ,but look for one
Jul 27, 2009 | 1996 Isuzu Rodeo
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
My protection light want shut off.
Not if the amp is damaged. An amp that remains in protect mode (after cycling the power) usually has an internal fault and must be repaired.
Aug 31, 2008 | Car Audio & Video
Mac-505 amp
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Dec 19, 2007 | Car Audio & Video
Wiring for 2500d orion amp
ground wires(heavy black)is connected when the red light lit.so no need check the red hot wire which is connected to battery terminal maybe loose.or theres no power comming in.thre are 2 hotwire in that amp one is red which is the main and yellow or sometimes orange which is the remote on. now if you sure that the power terminals is properly connected,ur speakers is working and input wires are good and still no sound. your amp is probably gone...do not try experimenting the wires or hook up two amp by any means..u might destroy all ur amp. hope this help u....
May 11, 2007 | Orion 2500D Car Audio Amplifier
Protection Light On
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance. A thumbs up would be greatly appreciated if this answer is helpful to you
Nov 26, 2006 | AudioBahn A8000T Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
51 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
