Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson vacuum beater bar takes a while to start working.
    Novelist:
  • 171 Answers
SmartAlec from NelsonVacuums.com.au here. If there are no bad sounds or smells when you are engaging the bar then it is a sign that your belts are stretched. The best plan of attack is to replace the clutch. This is not the easiest repair i would say a 6/10 for difficulty so if you are not really up for a repair yourself get a local repairer to do the job for you.
Hope this helps.
Happy Vacuuming
Regards Alec
Posted on Mar 07, 2010
Dyson canister DC39 - beater bar won't spin once it touches the floor
Some models have the beater bar driven by the airflow from the vacuum rather than a small motor. It takes a lot of suction to turn the brush roll. Make sure there are no restrictions which will reduce the airflow and suction. Replacing the filters may help if the vacuum motor still has adequate suction.
Sep 17, 2017 | Dyson Vacuums
My Dyson vaccum leaves a row of multiple lines on my plush carpet. I've never had s vaccum leave more than the two wheel lines. I called customer service and they had no solution for me!
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
May 03, 2017 | Dyson Vacuums
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to remove the head to get at the motor that drives the brush?
I don't know about the Dyson ,but the beater bar (brush) is run by a belt that you can see once you take off the beater bar cover
Apr 08, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
I have a Dyson Animal bagless vaccume and can not get the beater bar to work. I have cleaned it really good and seems that it doesn't switch from bare floor to carpet
Is this a new vacuum for you, or are you familiar with how it works? The beater bar button is on the front of the handle. It is a large half button with the picture of a beater bar on it. This button has to be pushed down for the bar to work.
If you already knew this and your vacuum is one you have had for awhile, it may have a worn or broken belt. The manual should tell you how to replace the belt, and you should be able to purchase one through the dyson website http://dyson.com under PARTS or at the store where you purchased the vacuum.
Please let me know if this works for you.
Jan 11, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Charlie
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
112 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
