My Mitsubishi projection tv VS 4561 only shows a blue screen in ANT A and ANT B mode no signals. I have an outdoor antenna and thought I should at least get snow but nothing. Do Ineed to change the settings?
  • 111 Answers
Go to menu and to net link reset back to factory defaults
Posted on Feb 03, 2010
I have a Mitsubishi VS-50705. It's a 50inch rear projection TV. The TV only allows me to switch between the ANT A and ANT B inputs, none of the others. When I plug in cable to either ANT A or ANT B nothing...
Hi con,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
Go to SET-UP in the MENU.
Then do a CHANNEL SCAN or AUTO PROGRAM SCAN.
You should be good to go..
Thanks for choosing FixYa.
John
Jan 06, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50603 does'nt get regular antenna chanels.
Indoor antennas have very limited capabilities especially in areas with elevation changes and heavy tree cover. Ideally, you should put an outdoor antenna on your roof or the highest elevation you can find with a relatively short distance to the TV. Make sure it has a good UHF section as this is where all digital broadcasts will be sent by the broadcasters as the digital transition occurs. You might try an amplified indoor antenna for better results than what you have now, but its no substitute for an outdoor antenna.
michtech
Feb 16, 2009 | Mitsubishi VS-50603 50" Rear Projection...
I am trying to remove the screen on my Mitsubishi VS-4561 rear projection tv to clean it, how do I remove it? I know it slides up, anyone have a manual???
For my VS-45607 I had to first take off the speaker grill. Then there is a panel just below the screen that can be removed with screws; I removed this just for wire clearance. Then there are a few screws that are along the bottom of the screen that you take off and you should be able to slide the screen up and off. Good luck.
Dec 02, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Hi, Vs-4561 MItsubishi rolling picture
Good Day, pleasehelptv;
Those caps may be the problem but try this:
VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING,VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
HOPE THIS WAS HELPFUL.
Good Luck, big IRISH.
May 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Blue screen
check the agc circuit it is becomming defected.good luck.
May 16, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
