Question about Canon DR-9080C Path-Through Scanner
I change the glass of the front reading unit and now comes the white sheet pink new glass will be my problem? postscript: is not the original
  • tom9788
    tom9788 Jan 08, 2013
    How do I change the front reading unit on the DR9080?
  • 490 Answers
The reading module is extremely sensitive. You need to handle very carefully. There appears an innocuous looking plastic strip, just under the glass, which is the LED unit. If it is disturbed, the lighting is affected and hence the output. (White light is a combination of RGB). When the intensity of the LEDs are affected you dont get right output. In my opinion it is difficult to fix this error. You may need to change the whole module.
S. Mohan
Posted on Feb 07, 2010
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
They are getting a warning on the light bulb\r\nSense Key=0x4 ASC=0x680 DDES=0x7E
Hi Dana,
The error you are receiving is Flatbed Optical Alarm.This alarm occurs when the READ command for the first document is received, or when gain of the CCD amplifier is adjusted (sheet guide is read) during scanning.Probable causes are:
- The lamp, optical system or white sheet guide is dirty
- Defective lamp, heater, CCD, or inverter
- Connector disconnected
  1. Does the same symptom occur after turning OFF and ON the scanner? Check the scanner.
  2. Is the White sheet guide (glass) in the FB cover dirty? Remove the FB cover and clean the White sheet guide (glass).
  3. Is the Optical unit dirty?Are cables damaged?Are the connectors connected properly?Check all.
  4. Do the Lamps FB light up?Are cables damaged? Are the connectors connected properly? Check if the lamps light up during the Paper feeding test.If not, the error is caused by the defective Lamp FB or Inverter.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 16, 2011 | Fujitsu fi-5750C Flatbed Scanner
My printer will not print. I recently changed ink cartridges and I'm getting a message suggesting that I realign something. How do I do that?
Most all-in-ones require you to scan an alignment sheet after changing the ink. Make sure the printer is on. Press Menu then use the up and down arrows to navigate to Maintenance. Click OK. Navigate to Auto Head Align and press OK. Select Yes and press OK. Load a sheet of Letter or A4 sized plain white paper in the rear tray, follow the on-screen directions. Open the output tray gently and the output tray extension. Press OK. When the page prints out, do not touch the printed sections. You should see a set of broken lines on the page, among other printing. The first section of columns will have 2 black, 1 blue and 3 black. The next row has 4 columns (blue and pink (to my eye)); the final row is 3 blue and 3 pink. If this prints okay, then select Yes and press OK. Next place the printed page face down on the glass of the scanner unit so that the black triangle at the top left of the page is in the left back corner of the glass. (The triangle is an alignment mark and lines up with the alignment mark on the edge of the scanner unit.) Close the document cover and press OK. The sheet will be scanned and the print heads will be adjusted. Do not open the document cover or move the sheet until the unit has completed the adjustment. Afterwards you can discard the sheet.
If the unit fails to adjust the print head, it will indicate this in the LCD screen. In that case, try manually adjusting the print head from the Canon Toolbox on your computer. If you can't get the printhead to align properly manually, the unit may need service.
For pictures, see the manual or support for the all-in-one here: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp490#ServiceAndSupport . If you use the Support option, search for align print head.
I hope this helps.
Mar 16, 2011 | Canon MP490 InkJet Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
The scanner is reporting an E2 error code when it draws a document in. Any ideas? Re-cycling the power clears error but comes back when I scan. thankyou in advance
This error message means ADF front side scanning optical alarm (lower optical unit ADF) which indicates ADF (front) lamp intensity check. Please follow the steps provided below:
1. Is the upper glass (white sheet guide)of the reading section dirty?
Open the ADF, and clean the sheet guide (white part) and the glass.
# When operating the scanner, the ADF’s inside glass becomes very hot. Take serious caution as the heat can cause burns. Before you clean the inside of the scanner, turn off its power and unplug the AC adapter from the outlet and wait (at least three minutes) until it gets cold.Be careful not to pinch your fingers when the ADF cover is being closed.
Note: Cleaning should be done approximately every 10,000 sheets scanned, though it may vary depending on types of
documents scanned. More frequent cleaning is necessary when the following types of documents are scanned:
- Smooth surface document such as coated paper
- Documents printed on almost entire surface
- Documents processed with chemical materials such as carbonless paper
- Paper with a high calcium content
- Pages with pencil lead
- Document where toner is not fused sufficiently.
If the above does not help, then the issue is caused by any of the followings for which you may have to contact the Fujitsu Expert/Engineer.
1. Lower Optical unit ADF may be dirty.
2. Lower lamp may not be functioning properly.
3. The connecting cables might be damaged.
4. The connectors are not connected properly.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5750C Flatbed Scanner
Anomaly in the light intensity of ADF front side. Fujitsu 5750c s
This error code denotes ADF front side scanning optical alarm (lower optical unit ADF) which indicates ADF (front) lamp intensity check. Please follow the steps provided below:
1. Lower Optical unit ADF may be dirty. (Remove any dirt inside of the mirrors and lens of the Optical unit ADF with blow brush. Do not use air sprays which may build up condensation on the mirrors.)
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Jun 28, 2010 | Fujitsu fi-5750C Flatbed Scanner
I need to change from feeding multiple originals from the top external feed to one sheet copying on the scan bed
If I understand you, just put the original on the glass instead of using the Auto Document Feeder.
Apr 08, 2010 | Canon PC-1060 Black and White Copier
Repairs of sharp AL 1000 flashaing E and 7
The scanner is not reading the white reference strip under the glass properly. You will need to clean or have cleaned the scanner optics and at least the white strip under the original glass. This strip is located under the left edge of the glass...under the scale that has the original sizing on it. The machine uses this strip on start up to reference the scanner. Simple fix.
Oct 21, 2009 | Sharp AL-1000 Copier
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon DR-9080C Path-Through Scanner Logo
471 people viewed this question
old marine
old marine
