Question about Coffee Makers & Espresso Machines
Gaggia Classic coffee pump does not function properly
I have a Gaggia Classic expresso machine. Pump does not function properly , no coffee or water, priming does work through the steam nozzle, but not through the brewhead. Have cleaned all except can not get the filterholderseal from the brewhead. Help Does it need to come off?
    President:
  • 1,618 Answers
Use the bottom pic for help.
Posted on Mar 04, 2010
My Gaggia Classic makes a noise that sounds like something is stuck and no coffee comes out. Can I fis it my self? Jon
as far as i know:
if water comes out thru the open steam exit running the pump, get out the vinegar immediately ( it/s eating the alu boiler) dissemble magnet valve and free the little whole in it with a needle, machine should run again, otherwise check electric function of magnet valve.
if no water comes out of the machine through the open steam exit, open the boiler immediately, get out the vinegar and check the pump.
greetings - mark
Jan 13, 2015 | Gaggia Coffee Makers & Espresso Machines
Pump won't prime
Needs De Scaling. Franko
Dec 31, 2013 | Gaggia Classic Espresso Machine
Hi I have gaggia classic cofe machine. It is used once in a week. Two weeks ago my gaggia stop pump woter in to coffe mug. Just like its not strong to pump water thru all the system. Never have this...
Remove the screw and shower screen, make sure screen is clean and you can see through all the holes in it, if not set screen on the stove (open flame) to burn out the coffee oils in the filter. The coffee will burn before the screen gets any damage. When done you should have a new screen reassemble and test.
May 20, 2011 | Gaggia Classic Brushed Stainless Steel...
I have the gaggia classic expresso machine but i don't have the operating manual. Can you please adviise where i can down load it from?
If you copy and paste this link to your browser it will take you to a page with all the Gaggia PDF manuals you require including the Classic. http://www.homewares.co.uk/gaggiaspecialists/10091.html
All the best
David
Domestic Espresso
Nov 07, 2010 | Gaggia Classic Espresso Machine
Hi, My Gaggia Classic is not working. No water
try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 29, 2010 | Gaggia Classic Espresso Machine
Hi. My Gaggia Classic doesn't prime. The pump makes a noise, the boiler gets hot but no water is sucked up out of the reservoir - please help!
I have a Gaggia Espresso maker and to prime it I have to remove the reservoir and use a tall glass next to the machine so that the hose is almost flat. It seems to **** the water up easier that way. Good luck.
Apr 11, 2010 | Gaggia Classic Espresso Machine
Gaggia Classic - No Heat, Hot Water or Steam
There is a thermostat on the boiler disconnect and check to see if you can get a reading using an ohmsmeter, if no reading replace the thermostat. If you get a good reading then disconnect the element and check for resistance.
Dec 16, 2008 | Gaggia Classic Espresso Machine
Gaggia cffee machine will not pump water through th coffee
my gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Jul 06, 2008 | Gaggia Classic Brushed Stainless Steel...
Coffee Makers & Espresso Machines Logo
606 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
