Question about Philips DVD 622 DVD Player
Phillips DVD player, No sound
Dad bought a cheep player a year ago and it only played a dozen times and the sound went out. Has a loud hum on the individual hook ups and no sound with the single multi pronged cord.
  • Anonymous Jul 14, 2008
    no sound when I hit play
  • Anonymous Sep 02, 2008
    This is my second Philips DVD 622 and I had the same sound problem with both players. I can use Xbox with no problem, so I know it isn't the audio/visual plugs.
  • 8,596 Answers
Swap out the red/whites - loud hum means something isn't hooked up right
Make sure a/v cables going OUT from dvp and IN to tv
Posted on Sep 04, 2008
DVD player created 60 cycle hum
You can get a new one.i bought one at ankaka,very cheap but it works very great.
Feb 10, 2013 | Televison & Video
Our Toshiba 23HLV87 combo TV won't eject the DVD. We've had the TV 2.5 years and about a year ago, this problem would occasionally happen. Eventually we could get the disk to come out with patience and...
Hello Friend,
A small belt that connects the motor and the DVD tray is worn out or lost its elasticity, ask your nearest authorized service provider to visit and replace it.
Good Luck.
Dec 20, 2010 | Toshiba 23HLV87 23 in. LCD Television
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
I have a phillips dvd player DVP 3982 that I bought so that I could play dvd's that I have from South Africa. B & H in New York guaranteed that it would play all these dvd's. But every time I put one...
if its a burned dvd it might not play. i had the same problem with my DVD player. i forgot what make and model it was but, i just went out and got a new one.
Oct 08, 2009 | Philips DVP3982 DVD Player
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
Nov 16, 2008 | Philips Televison & Video
Phillips DVDR3320V 'disc unknown' error
Hey there,
Have you tryed different types of DVDs. You might need to buy DVDs that say DVD RW.
Jan 27, 2008 | Televison & Video
Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
Nov 13, 2006 | Sony DVP-NS55P DVD Player
Philips DVD 622 DVD Player Logo
371 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
