Question about Sharp R-1870 Convection/Microwave Oven
Is there a fuse in these oven, on power - Sharp R-1870 Convection/Microwave Oven
  • 73 Answers
Yes, there is a fuse in every oven on power, just follow the mains cord coming in the microwave
Posted on Feb 02, 2010
Where do I find the fuse on my hood microwave?
Unplug the microwave oven, remove the cover, then follow the area where the power cord goes into the oven. There should be a small ceramic fuse snapped into a holder. Check the schematic diagram inside the oven. A continuity tester will tell you if there's a problem with the fuse or the power cord.
Dec 21, 2014 | Microwave Ovens
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Power just stopped working. Is there a fuse built into the oven?
Yes there is a fuse which is built within the oven. Open the back cover and locate the fuse which is located in the power supply board. Replace it with same value.
Dec 02, 2010 | Sharp R-1380 Microwave Oven
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
No power I checked the power outlet and I have 115V there Is there a fuse some ware??
If everything is ok, the fuse of microwave oven is located inside the unit, if you have a screwdriver, unplug the power cord and open it, you'll find the fuse
Aug 09, 2009 | Frigidaire PLMV169DC Microwave Oven
I have a Kenmore Microwave Oven - Elite Series - only about 3 years old, keeps blowing fuses - any advice on what might be the problem? I think the first fuse blew during a power outage, not sure if that...
make sure you have the oven plugged into a designated outlet...what I mean by that is...the outlet your plugging your oven into must be wired right to the fuse box by itself...because the oven will take most of the power from that one fuse for itself...also make sure the fuse is rated for what the oven needs....on the back of the oven, it will tell you how much current it takes...(???Amps), if it says 12 amps for example...the fuse should be 15 amps...if its lower that 12...it will keep blowing....if all of what I said check out then your oven has developed a short circuit...most likely the high voltage diode or magnetron....have it serviced....
Jul 25, 2009 | Microwave Ovens
Kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
May 29, 2009 | Kenmore 63792 Microwave Oven
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave has no power
Hi
Thanks
Rylee
Jan 15, 2009 | Whirlpool MH7135XE Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
103 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
