Question about Dell 3200MP Multimedia Projector
Dell 3200mp lamp not working
I replaced the lamp in my Dell 3200mp projector when the lamp indicator came on. After replacing the lamp with a new one the same problem exists. The lamp indicator is on and the lamp will not even attempt to light. Anything else I can check?
  • Anonymous Apr 13, 2009
    i have the same problem
Dude! You just saved me 250.00..It worked...I could kiss you!! ...HA! HA!...:)
Posted on May 01, 2010
  • Frsoty Thompson Dec 13, 2011
    I called a half dozen local repair shops, but none of them would work on my 3200MP. So I called 3 repair shops on the Internet and it sounded like the estimated repairs would be $200-300. I decided to look one more time on the Net and found Fixya. I read the solution to clean the circuit boards, free them of dust, and our projector has been working like new ever since! Thank you!
Check out this link with the solution:
http://www.dellcommunity.com/supportforums/board/message?board.id=proj_2200MP&message.id=2136
i'll also copy and paste it below:
Mods, this should DEFINITELY be in the FAQ's. ***This should probably only be done if your warranty is expired, i'm not sure if taking apart your projector will void it or not, so do at your own risk. (Personally I had nothing to lose, the projector wouldn't work and Dell wouldn't help me so I had a $1500 pile of plastic with no good use) OKAY, if your projector is flickering, the picture is jumping up down left and right, then it shuts down and the lamp light comes on it is NOT THE LAMP!!! Don't let anyone tell you otherwise! Well,,, at least try this first. For some reason dust on the main board causes this, sounds ridiculous but it's true. I have a 3200mp and just did this 2 hours ago and the projector is as good as new. For a 3200mp: There are four very small phillips screws on the bottom of the projector... remove those. There is one very small phillips screw on the right hand side of the unit if you are looking at the projector from the front.... remove that. Now flip the unit so it is right side up and remove the top piece of plastic (The bottom doesn't come off at all. BE CAREFUL, THERE IS A RIBBON ATTACHED TO THE TOP PIECE SO LEAN IT AGAINST SOMETHING. Now grab a vacuum and your air compressor (or can of duster) and go to town. There will be huge plumes of dust come from under the lamp so keep your vacuum close. Next take the lamp out and clean off the glass lens (there is probably some dust on it) Put it all back together and it should work like a charm!
Posted on Feb 24, 2008
  • DUC1198S Oct 18, 2010
    Awesome advice! Worked like a charm. My boss purchased a new projector for the office after a new bulb in the old one didn't fix the problem. He told me if I can get the old one working again I can have it! SCORE! THANKS!
  • John Hoog Jan 15, 2012
    Well done. What is actually happening is the color wheel and sensor assembly has become dusty. When the system begins to loose sync, the picture will begin to "jump" occasionally and then the lamp will shutoff and the lamp indicator will light, then after the lamp cool down cycle ends the projector shuts off.
    When blowing out your system with CLEAN compressed air, that you buy at WalMart or wherever, pay special attention to the color wheel assembly.
    The inside of my project looked fairly clean but a fair amount of dust was released from the center squirrel cage fan. I removed my lamp as part of the dis-assembly and cleaned it separately. Now re-assembled it works great!
Dell 3200MP DLP Projector: displays OK, but with vibrations soon as power button is pressed ON. found cause; rotating see thru thin plastic disk has a quarter of the disk broken off, thereby causing...
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Jul 04, 2011 | Dell 3200MP Multimedia Projector
Dell 3200mp lamp
are both of the lamps the same? have you installed it correctly in the socket. you might need to do a cold start for your projector. unlpugg it and try to wait for 5 minutes before plugging it again and turning it on. one your projector detected that a new lamp is intalled, it should work fine now. but if its still not working, you might want to try and replace the new lamp again. sometimes this happens.
hope this helps.
Feb 20, 2008 | Dell 3200MP Multimedia Projector
Replaced the lamp in my Dell 3200mp projector when the lamp indicator came on. After replacing the lamp indicator is off , but the lamp will not even attempt to light. Anything else I can check?
did the old lamp fail? Or did the lamp light just come on?
Firstly I would disconnect the mains and carefully put the old lamp back in. Test the projector. Then put the new one back in and test.
There can be problems with lamps not being seated correctly, and/or the lamp cover not being fully closed.
Post back for more help if required.
Dec 29, 2010 | Dell 3200MP Multimedia Projector
I need a new colour roller for the projector which is now out of manufacture and warranty
Go to ebay.com This projector is in good physical condition and powers on, but it only white. Lamp/bulb is NOT included.
Manufacturer: Dell
Model: 3200MP, 7W625
Cosmetics: Good
Test Results: Tested to power on only. Sold AS-IS, with NO warranty.
Accessories: Power Cable, Carrying Case
Nov 16, 2010 | Dell 3200MP Multimedia Projector
My projector not working error is TAMP WARNING LIGHT BILINKING
Replace the lamp
Check online at several places because some are rip-offs
Nov 03, 2010 | Dell 3200MP Multimedia Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Dell 3200mp
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @ussmillerco@yahoo.com and let me know. Good luck thx sean
Nov 21, 2008 | Dell 3200MP Multimedia Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
Dell 3200 Projector
Hi Tara
This normally indicates that the lamp will need replacement.
The Ibook and this Projector are compatible as long as you run a Microsoft operating system i.e. Windows 98' and higher.
When replacing the lamp , you can just as well clean out the Projector - this is quite important as it prolongs the life of your lamp.
May 18, 2008 | Dell 3200MP Multimedia Projector
Dell 3200mp
Hi Lagnitta
Take out the lamp and check for any irregularities like discolouration and marks.
This is unfortunately dammage to the lamp and the lamp will need replacement.
Thanks for using Fixya.
Apr 27, 2008 | Dell 3200MP Multimedia Projector
Dell 3200MP Multimedia Projector Logo
1,931 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
