Question about GE Washing Machines
Washing machine not spinning in the rinse cycle
  • 51 Answers
The pump is blocked, empty filter.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
  • 185 Answers
SOURCE: Brandt washing machine gets stuck at rinse
check the coupler it might be the timer
Posted on Mar 25, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 582 Answers
SOURCE: washing machine will not advance through the wash cycle
when it reaches the stopping point does it stop after the wash cycle if so try pushing the switch to the lid with a popsicle stick and see if it goes into the spin cycleif it does the lid switch is bad. the washer will not go into the spin cycle unless the lid is closed and if the swich is bad it won't let the time advance
Posted on Aug 12, 2009
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Washing Machines Logo
26 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
