Question about LG Bottom Freezer Refrigerator w/ Swing Freezer Door 19.7 Cu. Ft. - LRBN20512
Puddle underneath fridge on occasion--tube coming down seems ok
  • 585 Answers
This happens when the water from the defrost cycle exceeds the capacity of the pan under the fridge. The amount of water depends upon the door traffic (how many times opened in the day) humidity, and believe it or not, the door seals. If the doors to not seal or close properly, it will allow air, and the humidity that it carries, into the box, and that means more defrost water. You might also check the pan for physical damage that may make it leak.
Posted on Feb 03, 2010
Water underneath
This is not unusual because of the self defrost. The ice melts in the freezer and runs down a tube into a tray on the bottom of the unit. IF there is not enough airflow or a lot of debris in the tray then it wont evaporate or have room for water and you get a puddle.
Apr 25, 2016 | Kelvinator Refrigerator Fridge Freezer...
I have an artic king freezer model arco7mw and it has puddles of waterneath,why is that?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 02, 2015 | Refrigerators
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Why do i keep getting a puddle of water in the bottom of my frige? The water must be coming from the top because each day, there is water on top of the food containers all the way down to the bottom.
Sounds like you have a defrost drain issue. Often times these get clogged, and the back flow water drips into the fridge, usually the culprit on a GE is a clogged drain diverter, located on the outside back of the unit. Remove the tube by bending and pulling away from the diverter while holding the diverter firmly in place. Then turn the diverter one quater turn clockwise and it should pull down and away from the appliance. Clean this diverter out thoroughly, as it is likely full of gunk. However, on some older model GE top mounts, ive seen the drain pan underneath the evaporator coil inside the freezer with a small rust hole, and the water drips through this hole instead of the intended drain hole, the water then misses the tubing, and drips into the fridge. this drain pan will then have to be replaced.
Dec 10, 2010 | GE Refrigerators
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a fridge freezer (can't remember exact model) however we seem to get a small puddle of water at the bottom of the fridge section (front left as you look at it to be precise) although the fridge...
check if there is a gulley on the back wall of the fridge with a drain hole in the middle. if so, this drain may be blocked. poke something flexible down the drain till water flows away freely
Sep 17, 2008 | Bosch Refrigerators
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Samsung side by side
This is an issue brought about by the defrost cycle. Usually, the condensate goes into a small pan under the unit where it evaporates. You will likely find that the tubes coming down from the unit to the pan underneath the box are clogged with dust. While you're there, clean the condenser coils.
Dec 30, 2007 | Samsung RS2534 Side by Side Refrigerator
LG Bottom Freezer Refrigerator w/ Swing Freezer Door 19.7 Cu. Ft. - LRBN20512 Logo
87 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
