I have a Sony Trinitron Model KV-29XBR85, purchased in 1989. Turning it on earlier this week, the picture horizontal (left and right sides) frame is caved in, so the picture is now in the shape of an hour glass. The older tvs had a horizontal and vertical hold adjustment. This tv does not. I am wondering if there is some adjustment that I could perform internally. I'd hate to give the tv up as I've grown attached to it, while my wife is secretly routing for a flat screen and is happy.
  • jvforte Feb 03, 2010
    Hi Dan,
    Thanks for your email. Yes, the picture is still good except for the "squeeze" from either end, which does distort the wording at the bottom of a newscast, etc., but the picture seems OK other than that.
    Jim
  • 4,234 Answers
This is a pincushion problem that can be as simple as a poor solder connection. Is the picture still a good quality (except for the curve)?
Finding someone to work on this may be tricky and the labor cost is likely to exceed $100. I would inquire at a couple of repair shops to get a verbal estimate based upon the model and the symptom before a decision is made. In the meantime, I'll look up the model to tyr and estimate the parts cost.
Dan
Posted on Feb 03, 2010
  • ABRsvcs Feb 03, 2010
    I'll need to do some more hunting for the service manual for your model. I don't have it electronically. A paper search is needed. Stay tuned...
I have a sony trinitron kd-32fs170....all i get is 4 red blinks no picture
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
No frame in other words.
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
May 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture or sound
6 blinks usually means a loss of the horizontal signal. This can be as simple as a bad capacitor or jungle IC. I'll look up your specific model, but do you intend to repair this yourself? If so, please update this and I'll provide additional details and instructions.
Dan
Mar 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Very old Sony Trinitron
Hello gemdsimm,
You right, its cuased by power surge and you should contact nearest Sony service shop for proper repair.
May 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blank screen on sony trinitron tv
The problem with this model is the large parts due to poor wave soldering. Locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down.
Dec 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron kv-35 s 45
OPTION 1- TAKE THE BACK OFF THERE ARE 2 SMALL SCREWS YOU WILL NEED A SMALL SCREW DRIVER TWIST THE ONE ON TH RIGHT UNTIL BLINKING GOES AWAY THE VIBRATION FROM THE VOLUME WILL CAUSE IT TO GO OUT OF WHACK AGAIN SHORTLY WITH IN WEEKS. JUST KEEP DOING THIS.
OPTION 2 - TAKE THE TV OUT BACK GO TO YOUR LOCAL SPORTSMAN WHAREHOUSE PURCHASE A SKS AND SHOOT THE CRAP OUT OF THE PEICE OF CRAP. THEN GET A CREIDT CARD AND PURCHASE A NEW LCD NOT A PLASMA
Dec 26, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lightning hit sony kv29xbr85
If it was me...I would first check the series of fuses on you main circuit board. Look for any burned components.
Dec 16, 2007 | Sony KP-46WT500 46" Rear Projection...
Trinitron- hourglass?
You very likely have loose conection in the horizontal drive transformer,dont use or it will blow up all the way.Good luck.
Aug 31, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
