Question about Samsung TXP3271H TV
How do I check/replace the fuses on a Samsung TXP3271H?
How do I check/replace the fuses on the power supply of my Samsung TXP3271H? The television no longer powers up and I believe checking the fuses is the next step after visually inspecting everything external.
  • 73 Answers
If the fuse is burnt, the wire inside will be broken or/and the fuse is black, if you have tester measure it for conductivity with ohmmeter. Replace with the same ratings fuse. If the TV doesn't power up other parts could be burnt and need replacement
Posted on Feb 03, 2010
Samsung tv CS-29M16MG fuse always blown
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 12, 2014 | Televison & Video
Wher is fuse fd102s located
check fuse FD802A on the power supply board it is also feeding the -30 volt line. FD102S is on the convergence board 3.5 amp pico fuse cb6844a9-6247-49fc-a85b-fbc69d68a3ea.jpg
Jun 25, 2014 | Samsung HCM5525W 55" Rear Projection...
When i switch on, it is always on standby mode, screen doesnst show picture
With the Samsung PPM42S3QX Power Supply Board is the likely the cause. Testing and diagnosing - Remove the back of the TV and check the voltages on the power supply. The output voltages will be labeled on the board. Look for obvious need for replacement such as swollen caps, bad fuse, burnt components.
Feb 17, 2012 | Samsung PPM42S3QX 42 in. HD-Ready LCD...
I have a Samsung 40" lcd model LN40A53OP1FX2A
Could be,might not also,any things on the power supply board could be burn and dies,when it getting to much electricity current to it.Dead or dying capacitors on the power supply board are alway bulges or puffing up on it tops.Check the power supply board carefully look at all the capacitors parts,if require replacing,u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braid,a roll of solders,also u must know basic soldering understand basic electronic to do it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Samsung LN40A530 40 in. LCD TV
TV TURNED OFF AND WON'T TURN BACK ON. NOW THE RED LIGHT JUST BLINKS, NO PICTURE OR SOUND.
You have either a bad relay or a bad capacitor inside the TV that will need repair or replacement. Most likely it is in the power supply section of the TV.
Nov 30, 2010 | Samsung TXP3271H TV
I have a samsung lcd ln40a330. When I try turning it on it does nothing. Is there a fuse to it.
Yes,the fuse in the power supply board,that the board,where the power a/c cord plug into it.Check ur power source?Yes,than the tv power supply board is dead.These modern circuit boards design never kill the fuse that easy.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 28, 2010 | Samsung LN40A530 40 in. LCD TV
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
My tv will not turn on. I have check the fuse and
Power supply board is dead.Replaced the power supply should solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Mar 30, 2010 | Samsung LE32A41B 32 in. HD-Ready LCD...
Tv does not come on
CHECK THE MAIN POWER SUPPLY , either for fuses or replace power supply board. hope it helps , AJ
May 07, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
It won't come on
Listen for noise when pressing power, if no noise then check powersupply for open fuse, then if fuse is good check for open circuit in PS. If hear noise then short is in PS
Aug 22, 2007 | Samsung TXP3271H TV
Televison & Video Logo
125 people viewed this question
Henry  Thomas
Henry Thomas
