Question about EA - Electronic Arts Need for Speed : Most Wanted
D3dx9.dll file is missing - EA - Electronic Arts Need for Speed : Most Wanted
D3dx9 41.dll file missing on acer 5315
you could download a dll fixer tool online.just google it
Jan 21, 2015 | Acer Aspire 5315 Notebook
I installed a game on acer aspire 5315 but it will not load due 2 d3dx9_41.dll missing. any help plz
Simply please try uninstalling the game and reinstall. If you are using a Windows Xp machine and it is a Laptop then it is likely the graphics card in the machine is not able to handle the level of graphics being displayed in the game.
If you are checking the graphics card driver you may want to take note of any stickers on the machine indicating the brand of graphics card for example if it is a NVIDIA graphics card you will need to go to the NVIDIA site download and install the most recent graphics driver for the card and try again. If it fails it is likely the video card not being able to handle the levels of graphics as mentioned before
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
May 12, 2010 | EA - Electronic Arts Command & Conquer 3:...
Downloading
This application has failed to start because d3dx9.37.dll was not found. Re installing the application may fix the problem.
Jul 25, 2009 | Microsoft Windows XP Professional With...
Cant find d3dx_dll at my laptop built-in video card
Install DirectX.
http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
If you already have DirectX 9 installed, grab the missing DLL from here (the newest ones are at the bottom):
http://www.toymaker.info/Games/html/d3dx_dlls.html
Place them in c:\windows\system32
Apr 14, 2009 | Acer Computers & Internet
Prison tycoon 3
make sure you have the current version of Direct X installed, check the system requirments and be sure your system can handle the game.
I did a little reseacrh and its a file thats on the disk that should be copied when the game is installed, are you using a burned copy or the original?
Its a registry file thats not getting copied right, thats bassically it.
try this out, download it, scan for viruses as every good Nerd/tech would do and if its clean, unzip and install and see if it works. Lety me know.
http://www.dll-files.com/dllindex/pop.php?d3dx9_25
extract the file to your windows\system directory
i downloaded it and scanned it but do so anyway for safety.
Hope this helps
Feb 16, 2008 | E-Machines eMachines Desktop PC
EA - Electronic Arts Need for Speed : Most Wanted Logo
1,031 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
