Question about Palm Treo 500 Centro
My palm centro will not turn on the red light just blinks and occationally it does come on
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Hello abevagota25,
A flashing red indicator light (upper left-hand corner) occurs when the Centro is connecting to the the cell phone network. The light will continue to blink until it gets a strong enough signal to make a good connection. Try turning the phone on from different locations to see which one makes a good connection
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Feb 04, 2010
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
Treo very hot and not turning on
I think your battery failed. When the red light is on that indicates the unit is trying to charge the battery, and it usually will get a little warm, but if it's really hot then a cell in the battery has probably failed.
You will need to take it to a dealer and get a replacement battery. (I've had to replace the battery in my Centro twice since I got it a year ago!)
Sep 23, 2009 | Palm Treo 500 Centro
I tryed charging my palm centro with the USB cord and the red light came on but it didnt charge what do i do?
your laptop is plugged in right? I would check the battery options on your laptop.
Aug 30, 2009 | Palm Treo 500 Centro
I can't get my jawbone to pair with my palm centro any idea's
With the jawbone turned off, press at the same time the turn on button and the noise reduction button. The jawbone should blink white and red for three minutes, in that time you shoul be able to find it as a bluetooth device in the free hnd configuration of the palm centro. than yu complete the conection by inserting the code. The next time you turn on the jawbone it will connect with te palm.
Aug 09, 2009 | Palm Treo 500 Centro
My palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro does not turn on and the red light stays on
Hello halvarez,
Have you tried a soft reset by removing the battery and leaving it out for a couple minutes then reinserting it ? The Centro should run as normal after removing the battery and reinserting it. All your information is retained when you perform a soft reset.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
May 10, 2009 | Palm Treo 500 Centro
I drop my phone centro palm into water! I charge the phone and the red light turns on but my phone wont turn on at all. What can i do
Get a bowl of rice. Remove the battery from the phone. Leave the phone back open. Put phone and battery in the bowl of rice, cover and leave overnight.
The rice will hopefully soak up any water inside the phone and battery. If this doesn't work there may be permanent damage to the phone from the water and charging afterwords.
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Blinking Light
Sim card needed replacing
Jan 26, 2009 | Palm Treo 500 Centro
My palm centro wont turn on. it has the red light on but its not on the charger
hey i had the same problem but just a tad different, my phone just wouldt turn on in general so i plugged in the phone and just started messing with the keys, i dont know if that will help but its worth a try
Jan 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Treo 500 Centro Logo
925 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
